martijnoss Posted August 23, 2016 Posted August 23, 2016 Hello guys Maybe this is the wrong place for the topic i dont know but i cant find a support forum about media. A few themes in my system are not working properly, the wheel images are in the background of the theme or neginhd a layer. This question is asked more then once but i cant find a answer or direction to a solution. someone noticed this problem also. thanks
BATTLEDONKEY Posted August 23, 2016 Posted August 23, 2016 I've noticed some themes like this too, ie the neo geo pocket color (the black version in the download section). I'm beginning to get the hang of how to move layers around and customising it by editing values in the theme.xml, but nothing stands out to me about adjusting whether it's behind the wheel or not. I put it to the side because I havent set that console up, but my OCD wants to figure it out for when I do set it up or another theme with the same problem because it obscures the wheel images and makes it hard to see the game names. Anyone know how to adjust that and can help out
thatman84 Posted August 23, 2016 Posted August 23, 2016 Found this link that explains theme layers really well. https://web.archive.org/web/20140325190617/http://hyperspin-fe.com/oldsite/index.php?option=com_content&view=article&id=68&Itemid=74 The bottom paragraph says the wheel will always be below Artwork 1-4 So it seems the only fix, if you have your wheel set permanently visible with no alpha fade, is to adjust the artwork positions in the xml or to use Hypertheme to adjust the artworks to suite your setup Don't take my word for this I may be wrong Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
