Xbox One Controller Stopped Working with HyperSpin after Windows 10 Anniversary Update
hyperspin21
I am running HyperSpin 1.4.15.  In HyperHQ I have Joystick 1 enabled.  This has always worked fine on WIndows 10 until recently.  I believe the anniversary update may have broken Xbox One wireless controller support for HyperSpin.  I have tried on 2 different computers and it is not working on either.  The interesting thing is that when hyperspin displays the startup animation if I press a button on my Xbox one controller it seems to skip the animation as if the key is detected.  Unfortunately, none of the keys seem to be recognized afterwards.  HyperHQ detects the controller and allows it to be mapped.
Anyone else have Windows 10 Anniversary Update with an Xbox One wireless controller?  Does it work for you?
let me know if you find a fix im having the same problem mate ill post here if i find one too.
my controller seems to start working after iv boot in to emulator and backing key board.
I use an wireless Xbox one controller with Win 10 Anniversary and it works fine. This isn't a Windows problem, if anything it's a HyperSpin problem - you may just need to remap the controls in HyperHQ. If that doesn't work HyperSpin would need to be updated.
Given that joypad support still isn't great in HS anyway - I'd advise turning off joypad support in HyperHQ and mapping button presses to keys with joy2key. This works way better anyway, and means that these sorts of problems won't arise again.
Cheers mate ill check it out tonight. iv tryed restting controller and remapping buttons in hq also tryed a different port on my pc but still no joy. I know my controller is working because it works in when i open a emulator the funny thing is when i exit the emulator and go back in to hyper spin it works again lol just no on boot
So i installed and configured joy2key in rocketlauncher but still only seems to be working when the app is open it seems like rocket launcher or something is not enableing the joy2key to boot when i open hyperspin.
Ok joy2key diddent work but iv found a workaround that will do for me for now when i hit the middle x button on my 360 controller i had a xbox window pop up iv just disabled it now i have another xbox window pop up showing my battrylife when i hit that button so i now open hyperspin double tap my middle button and its now working iv disabled joy to key also reenabled hyperhq joykeys and clicked a setting in rocketlaunchui rlui tab enablejoystick options its working for me for now so im happy for now lol let me know if anyone finds a proper fix thanks
Having the same issue here... The controller maps fine in HyperHQ and then is able to "bypass: the intro screen... but is completely dead upon hitting the main wheel.
I tried the above workaround from the lack of punctuation post above, does not work for me.
Very much feels like a windows 10 update is crushing HS somehow on this. This setup worked fine for 10 months.
Running HyperSpin 1.4.0 on Windows 10.
Am I SOL? Should I true the above keymapping solution? I fear the worse when i comes to all my hard work mapping keys on individual emulators within RL...
Im going to start a feesh hyperspin tonight to see if iv done anything wrong but i recon windows 10 is playing a part in disrupting controller on start.
Quick run down on how i got it to work again with my workaround if you may have missed something.
Disable any keymapper you have done eg joy2keys. Disable any settings you have done for this in rlui.
Go to rocketlauncherui in rlui click rlui tab and find/tick emable joystick.
Go to hyperhqand enable joystick.
Disable xbox middle button for xbox black bar.
Now what iv got when i hit my middle button is a battry bar.
Open hyperspin hit the middle button you should see a battry bar hit it aban it should disapear now mine works its a pain but it works for me lol
So iv started a fresh hyperspin and i have not connected it to rocketlauncherui so its just using hyperhq for the controller and it still dosent work. It seems to still work with my workaroud that i posted above tho. so now i know it has nothing to do with rocketlauncher its got to be windows based problem.
This is all easily fixed by using Joy2Key and keyboard settings in HyperHQ.  Joystick support in HS is still quite bad, so you're always better not to use it.
I used to use Xpadder with Windows 10 Anniversary (Now i can't because i changed to IPAC Ultimate). It emulates a keyboard from the Xbox controllers (or other Gamepads). If need more help just ask me!
I try'd joy2key and went over the the guide a few times to see if i made any mistakes but it still did not work. Could this be due to having a wireless keyboard? I dont mind too much tho because i can get it to work just by pressing my middle button a couple of times when in hyperspin now i have hidden the balck xbox band that pops up. Just wanted to know what was causing the issue so i could have a quick go of getting rid of it but it seems a bigger job than i thought thanks any way guys
I fired up Hyperspin yesterday to play Viewtiful Joe with my X bone controller connected and it was shocking. It took ages to land on the game, so I might be switching back to the startup script.
Would i have to downgrade hyperspin to use startup script? I have only started using hs on windows recently. With my new pc but i do have alot ov vids and other media from my android setup that i collected over the past few months for my nvidia tab. works brill but tops out at psp ps1 so want to get a setup going but whilst im at the beggining still im all ears
I don't think so although I've not used it since changing to 1.4. You just set it up and add it as a start program in HyperHQ, if it doesn't work just remove it and try JoytoKey.
