gigapig Posted September 7, 2016 Posted September 7, 2016 File Name: Demul Xbox 360 Control Configs File Submitter: gigapig File Submitted: 07 Sep 2016 File Category: Other Credits: Urbangangsta101 Original threadhttp://www.hyperspin-fe.com/topic/7830-demul-full-xbox-360-controls-for-naomi-and-atomiswave-enjoy/?hl=%2Bdemul+%2Bcontrol Demul - Sega Naomi & Sammy Atomiswave control configs for Xbox 360 ControllerBy urbangangsta101Demu 0.582Sammy Atomiswave XML v1.1Sega Naomi XML v1.2 Installation: (Essential)- Put the nvram folder into your Demul emulator folder (Overwrite any existing files)- Put the Demul (v0.5.8).ini into your Hyperlaunch Demul module folder (Overwrite any existing file) Extra Steps: (Not essential)- Enable Keyboard in Port C of the Demul plugins menu (Config->Maple Device Manager->Port C = Keyboard) - For 'Keyboard' style games- Add 'Mahjong' controls to your padDemul.ini (see demul-naomi-non-standard-controls.pdf)- Map controls for the 4 'Trackball' style games using Xpadder (see demul-naomi-non-standard-controls.pdf)- Map controls for the 11 'Lightgun' style games using Xpadder (see demul-naomi-non-standard-controls.pdf & demu-atomiswave.pdf) You should really use an Aimtrak Lightgun - Map controls for 1 'Touch Screen' style game using Xpadder (see demul-naomi-non-standard-controls.pdf) Enjoy! Click here to download this file
abodetti Posted May 29, 2017 Posted May 29, 2017 Thank you very much for putting together - My question is what do we do with the second ini file (Demul v.o7). Is that just if we are using that version of demul?
gigapig Posted May 29, 2017 Author Posted May 29, 2017 2 minutes ago, abodetti said: Thank you very much for putting together - My question is what do we do with the second ini file (Demul v.o7). Is that just if we are using that version of demul? Correct.
Tomkun Posted June 13, 2017 Posted June 13, 2017 Sorry to raise an old thread, but I'm just starting to get demul set up and there are a few things I don't understand. First, there are a lot of games in the database that are not in these config files. Is there a reason for that? i.e, they don't work or they are clones? Second, there is a 'null' profile, with no settings mapped. What's the purpose of that? Thanks!
gigapig Posted June 13, 2017 Author Posted June 13, 2017 9 hours ago, Tomkun said: Sorry to raise an old thread, but I'm just starting to get demul set up and there are a few things I don't understand. First, there are a lot of games in the database that are not in these config files. Is there a reason for that? i.e, they don't work or they are clones? Second, there is a 'null' profile, with no settings mapped. What's the purpose of that? Thanks! Not sure if Urbangangsta is around anymore so I will answer one of your questions. The config files came before some of the newer games so they won't have configs. I suppose similar configs could be used for the new games.
ci2own Posted June 29, 2017 Posted June 29, 2017 Does any DEMUL game use analog controls for Brake, Accel, Steering,etc? I checked (for example) "Faster Than Speed" and it doesn't matter if you press a little bit or if you push at all. Is the same! So if all games uses buttons all controls as digital (pressed/not pressed) i could map for Arcade Joystics too (not only for xbox 360 controllers)
