Fusion in HyperSpin - CANNOT LOAD SEGA CD game
nlen83
Hi guys,
I am losing my mind on this one. I am fairly new to hyperspin but definitely know my way around to get things working. I have fusion working with genesis/mega drive games no problem and I can run Earthworm Jim Special sega CD outside of hyperspin in Fusion no problem. As it is, when I select the game in hyperspin it just goes to a black screen most of the time and nothing happens. I get no errors.
Any thoughts would truly be appreciated!
Thank you for getting back to me! I am using rocketlauncher and hyperspin with Fusion - Hopefully this helps...
20:49:27:976 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
20:49:28:066 | RL |      INFO  | +93    | Main - System Specs:
RocketLauncher Dir: C:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 10 Pro
SKU: Professional
Total Memory: 16336.60 MB
Free Memory: 13144.27 MB
Used Memory: 3192.328 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 8
GPU 1 Name: NVIDIA GeForce GTX 980
GPU 1 RAM: -1.00 MB
GPU 1 Driver Version: 21.21.13.7254
Sound 1 Device: NVIDIA High Definition Audio
Sound 1 Status: Enabled
Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Sound 2 Status: Enabled
Sound 3 Device: High Definition Audio Device
Sound 3 Status: Enabled
OS Language: English_United_Kingdom
System Locale: en-US
Formats Locale: en-US
Windows UI Language: en-GB
Text Encoding: Windows-1252
OS Admin Status: No
RL Compatibility Flags:  HIGHDPIAWARE
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1020 work) [32bit] [60hz] [Landscape]  (Primary)
Current AHK Desktop Width: 1920
Current AHK Desktop Height: 1080
Monitor #1 DPI: 150
ErrorMode: 0
AutoHotkey Path:
AHK Version: 1.1.13.00
Unicode: No
20:49:28:066 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists
20:49:28:066 | RL |      INFO  | +0     | Main - Raw CLI received: "Sega Genesis Earthworm Jim - Special Edition (USA)"
20:49:28:066 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "RocketLauncherUI"
20:49:28:066 | RL |      INFO  | +0     | Process.Process - "Exist" "HyperSpin.exe"
20:49:28:069 | RL |      INFO  | +0     | Main - Detected HyperSpin.exe is currently running
20:49:28:069 | RL |      INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
20:49:28:069 | RL |      INFO  | +0     | Main - RocketLauncher received "Sega Genesis" and "Earthworm Jim - Special Edition (USA)"
20:49:28:073 | RL |      INFO  | +0     | Main - Did not find a "C:\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options.
20:49:28:073 | RL |      INFO  | +0     | Main - Earthworm Jim - Special Edition (USA) is using the default emulator: Fusion364
20:49:28:073 | RL |      INFO  | +0     | Main - Checking for a [Fusion364] section in C:\RocketLauncher\Settings\Sega Genesis\Emulators.ini
20:49:28:073 | RL |      INFO  | +0     | Main - Found [Fusion364] in C:\RocketLauncher\Settings\Sega Genesis\Emulators.ini
20:49:28:073 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Modules\Fusion\Fusion.ahk exists
20:49:28:076 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
20:49:28:076 | RL |      INFO  | +0     | Main - Earthworm Jim - Special Edition (USA) will use module: C:\RocketLauncher\Modules\Fusion\Fusion.ahk
20:49:28:078 | RL |   WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Global RocketLauncher.ini"
20:49:28:078 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\RocketLauncher\Settings\Sega Genesis\RocketLauncher.ini"
20:49:28:093 | RL |      INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
20:49:28:095 | RL |      INFO  | +16    | CheckFile - Checking if C:\HyperSpin\Emulators\Fusion364\Fusion.exe exists
20:49:28:095 | RL |      INFO  | +0     | Main - INI Keys read
20:49:28:095 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists
20:49:28:095 | RL |      INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists
20:49:28:098 | RL |      INFO  | +0     | Main - "Earthworm Jim - Special Edition (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Started
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).7z
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).7z
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Rom not found
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).zip
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).zip
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).sg
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).sg
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).sc
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).sc
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).gg
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).gg
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).sms
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).sms
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).gen
20:49:28:098 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).gen
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Rom not found
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).32x
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).32x
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).md
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA)\Earthworm Jim - Special Edition (USA).md
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).cue
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Found rom: C:\HyperSpin\Emulators\Fusion364\roms\Earthworm Jim - Special Edition (USA).cue
20:49:28:099 | RL |      INFO  | +0     | CheckPaths - Ended
20:49:28:099 | RL |      INFO  | +0     | BuildScript - User Variables:
Since u have it running in fusion on its own I'm guessing ur bios works and is set up properly.
Try going into the module settings for fusion inside rocketlauncherui and change perfect sync (I think that's what it's called) on/off for the game.
Some games require it on, n others off for them to work, I'm not at home right now so I couldn't tell u if Earthworm Jim needs it on or off
interesting enough I could never get fusion to work with the sega cd with the few games I had.. from RL it always opened up the emulator and gave some error about the drive/cd or something that I can't remember.. (the games worked fine outside of HS/RL) I recently got a full set of sega cd stuff from you know where.... and figured I'd give it another run.. but was using Gens.. however after reading this thread I decided to switch over to Fusion in RL just to see what the error was... but to my surprise Fusion is now working... the only thing that I changed is I'm using a new set of games which were zipped and I believe .rar as well... so I changed the .7z setting to true... that's about all I can remember doing.
Fusion seems like such a better emulator than Gens... in my opinion but I'm sure others would suggest RetroArch for everything.
Thank you for the replies guys. I will give this stuff a shot when I get home from work. FYI, fusion is working 100% perfectly for all Genesis and my one earthworm Jim Sega CD game outside of hyperspin. I do have the bios set for Sega CD. I also updated the extensions to everything I could think of including the bin and cue that earthworm Jim uses.
