Secret Menu Option?
Jenna573
Hello, I am new to the forums and HyperSpin in general, so I apologize if I accidentally break a rule that wasn't touched upon in the general forum rules.
I am curious to know if there is any option or setting or some such that I can do in order to create a hidden menu that isn't normally select-able, but will show up upon entering a sequence of key presses/inputs. For example:
>scrolling through lists like normal
>decide to enter Konami code...
>BOOM! I am entered into a secret list of extra games.
Is that possible to set up? Thank you and/or sorry in advance!
I should have named the topic Option for Secret Menu instead of Secret Menu Option, haha. Hindsight, etc.
Still, if you have any idea, let me know! :3
Just use the Genre system for that. Just define the key for Genre as some complicated bs key combination to hide your hentai games. The rest is just xml stuff.
You could also use an AHK script to swap out your Main Menu.xml via simple file copy. Then, when you go into a system wheel and back out, after loading the AHK script via hotkey, the system would appear. Use the same principal to hide it again. I've used this approach to test switching between Arcade / PC / Console menus. Works perfectly.
Hahaha this actually sounds like an awesome idea. Not for Hentai games haha, but I think it would be awesome to have a hidden romhack menu for each system like this.
So like, enter the 'code' and then BAM, wheel switches over to the 'genre': romhacks.
The trick would be making it so they only pop up on the genre wheel though, and not in the full-list.
