danielm7999 Posted October 20, 2016 Posted October 20, 2016 Hi, Ive got Win XP 32 SP2 with an Arcade VGA and Im running into an issue where Hyperspin crashes my PC after the Hyperspin intro vid, right when the game video tries to load. Doesnt matter what game you scroll to. See the vid for a better idea: Ive read other peoples similar issues that have to do with installing flash, but this winXP SP2 wont install flash player. Apparently I would need SP3 and I dont want to update to SP3, for lots of reasons. I tried turning off video acceleration in Windows Media Player but that didnt help. Here is my Hyperspin log: 01:58:58 PM | HyperSpin Started01:58:58 PM | Going FullScreen01:58:58 PM | Checking for updates01:58:58 PM | Update Check Complete01:58:58 PM | Startup program unavailable01:58:58 PM | Playing intro video01:59:16 PM | Error intializing joysticks01:59:16 PM | Menu Mode is multi01:59:16 PM | Loading Main Menu.xml01:59:17 PM | Main Menu.xml successfully loaded01:59:17 PM | Main Menu wheel loaded successfully Not sure what other info you may need. Anyone else have Hyperspin running correctly in XP SP2? With Arcade VGA?
32assassin Posted October 20, 2016 Posted October 20, 2016 Hyperspin needs flash to work, Most of the custom animation inside themes are Flash Based. if you remove ALL the Main Menu themes you might keep your PC from Crashing. But the Fact is; if you do not want to install flash on your PC, the only option you have is to look for another Front end. edit and you should detele all your Transition videos go to HyperSpin\Media\Main Menu\Video\Override Transitions VIdeo Transition format = FLV = Flash Video
Metalzoic Posted October 20, 2016 Posted October 20, 2016 I don't know the answer to your specific question, but I've seen a bunch of people have trouble trying to use the Arcade VGA card. Good luck figuring it out. Sent from my SM-G935V
danielm7999 Posted October 20, 2016 Author Posted October 20, 2016 Thanks so much guys - I appreciate the advice! So if I upgrade to XP Service Pack 3 then will Hyperspin, MAME, and Arcade VGA still work? Cant remember if I read that SP3 will not work with one or more of those.
32assassin Posted October 21, 2016 Posted October 21, 2016 you have a very specific question regarding a 3rd party hardware. I never read a post of anyone having a system broken by SP3 (MAME or Hyeperspin). But then again their are not many people who are still running XP. I think your best option is to go ask the developers/ or someone who is using Arcade VGA if I was you, I would install SP3 and Flash then see how everything works. You can always re install windows XP with SP2 and move on from Hyperspin, if You encounter more problems then solutions.
