Grand Theft Auto - Mission Pack #1 - London 1969 (USA) PS1
Creezz67
Hi,
Does anyone know how to start this game for PS1 ?
It just says please insert Grand Theft Auto Disc and then says wrong disc
Thanks in advance
If you search around on the internet you can find a patched version that doesn't require the grand theft auto disc, that's what I use.
I've read that the Europe version also doesn't require you to swap discs but I haven't tried that version myself.
Other then that you will need to use the swap disc options of the emulator you are trying to use
Check this link and the replies below it- discussion on loading this game.
http://www.hyperspin-fe.com/forums/topic/11447-clean-psx-xml/?do=findComment&comment=206594
I believe it had two solutions. 1.-Change the game names in the xml so the GTA London disc shows as a related "disc 2", not as "Mission Pack#1 London 1969" through HyperPause (not well received due to xml game naming convention) or 2.-use an m3u (playlist) inside the rom zip, pointing to the cue files for both games and use native m3u loading with Mednafen. At that time, I tested the m3u method since that was the most acceptable, but also because only clues were provided so everyone had to piece together their own solution.
tried name change and it works, but as soon as you press X it says incorrect disc, load GTA disc
I think I will admit defeat as none of the versions of the rom work, tried v1.0,v1.1 and NTSC version.
ps, Don't understand how to create a m3u file inside each rom ?
Thanks anyway for info
