Pouteur Posted November 29, 2016 Posted November 29, 2016 Hi guys, I've just seen a video of hyperspin on shield tv (with hyperspin apk) and there is some override transitions on main menu theme. I've find where i have to put the video for override transition, it's in "Media/Main menu/Video/override transition" so i did it. My videos on the file "override transition" are in .mp4 and they have the same name as the system theme and system videos but it doesn't work. Is there any option i have to activate or any setting i have to modified to make it worked ?
thatman84 Posted November 29, 2016 Posted November 29, 2016 I wrote some stuff about this here Think they need to be .flv but I have just changed .mp4 extension to .flv for other videos with no problem but not sure how it will work with OT. there are some packs of transitions about. Search the DL section Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
reznnate Posted November 29, 2016 Posted November 29, 2016 I believe only .flv's were intended as overlay videos because they can include an alpha channel. The video player should still work if you rename .mp4's as .flv, but it will be full opaque video playback.
Pouteur Posted November 30, 2016 Author Posted November 30, 2016 Thanks thatman84 it works ! I change false by true in Animated_Backgrounds in setting.ini
