I'm having issues with video on Capcom Classics, Nintendo Classics, ect.
Espgod
Hey everyone, I've been trying to set up different wheels for MAME and I've run into an issue. I have all of my MAME videos in the MAME media folder and I have tried to direct the Capcom Classics.ini to the said folder but I isn't working. I've copied the MAME.ini and renamed it to Capcom Classics.ini and the video path looks like:
[video defaults]
path=H:\hyperspin\Media\MAME\Video\
Is there anything else I should change in the ini to get this to work?
The romsets may differ as well.   If you have separate romsets already, changing the emulator in settings/CapcomClassic.ini  to retroarch's fbalpha2012 core works for me.
Is there a 3rd party app that will copy over video files based on the xml or do I have to copy over the entire folder for each classics system? Because matching and copying over all of the files manually sounds like a nightmare.
For ones that don't have sets you can use Don's Hyperspin tools (renamer) to match them against the xml and then you select copy and choose a empty destination. Double check as Don's renamer is not perfect at fuzzy matching
I might as well get two birds with one stone here, do you guys know what text should be in the parameters in the ini for fbalpha2012? I really appreciate the help.
