Creezz67 Posted January 4, 2017 Posted January 4, 2017 Hi, Does anyone know how and what I convert these files to play Sega Saturn on NVIDIA SHIELD TV ? Tried as it is, but it says cannot initialise cd, unsupported cue file. Example: Advanced V.G. (Japan) SEGA SATURN Advanced V.G. (Japan) (Track 03).bin Advanced V.G. (Japan) (Track 04).bin Advanced V.G. (Japan) (Track 05).bin Advanced V.G. (Japan) (Track 06).bin Advanced V.G. (Japan) (Track 07).bin Advanced V.G. (Japan) (Track 08).bin Advanced V.G. (Japan) (Track 09).bin Advanced V.G. (Japan) (Track 10).bin Advanced V.G. (Japan) (Track 11).bin Advanced V.G. (Japan) (Track 12).bin Advanced V.G. (Japan) (Track 13).bin Advanced V.G. (Japan) (Track 14).bin Advanced V.G. (Japan) (Track 15).bin Advanced V.G. (Japan) (Track 16).bin Advanced V.G. (Japan) (Track 17).bin Advanced V.G. (Japan) (Track 18).bin Advanced V.G. (Japan) (Track 19).bin Advanced V.G. (Japan) (Track 20).bin Advanced V.G. (Japan) (Track 21).bin Advanced V.G. (Japan).cue Advanced V.G. (Japan) (Track 01).bin Advanced V.G. (Japan) (Track 02).bin Any help appreciated
thatman84 Posted January 4, 2017 Posted January 4, 2017 The 30 or so games I setup last night were all single bin/cue and the ones I teased with uoyabause work apart from no start button. have you opened your cue file and made sure all the bin file reference's are named the same as the actual bin's you have? you could try mounting the cue file To a virtual disk drive like Virtual Clone. then use ingBurn and create an image from disk. That may get you a single bin/cue. if not have a look about for darkwater or maybe redun sets. Think they are different file combos and single bin/cue Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted January 5, 2017 Author Posted January 5, 2017 Hi, These are Sega Saturn Japanese roms, Sega Saturn are all ok as just bin & cue like you say, but these ones are all like this. If search folders worked it would not be an issue, but as is, they won't work. Yes I also checked cue files are named correctly but no luck Thanks for info
