Zeaede Posted January 15, 2017 Posted January 15, 2017 I finally figured out how to setup retroarch emulators and roms of what i have tried so far But i have a question for setup controls Exampel, i set up NES and super mario world - it have 4 buttons select start jump speed/fire But if i setup nintendo 64 it have more buttons Should i have a seperate retroarch for each setup of emulator becouse of different button setup? Or if i set up NES and N64 are they having a seperate setup controller on same retroarch setup?
pofo14 Posted January 15, 2017 Posted January 15, 2017 No, you don't need that. You just need a different config per core. I'm not home now but can show u an example when I got home.
Zeaede Posted January 16, 2017 Author Posted January 16, 2017 If i first set up controls for NES then go with N64 It still shows same control setups for both emulators That i haven't figured it out if you can have 2 different control setups with 2 different emulators on same arch setup
Zeaede Posted January 17, 2017 Author Posted January 17, 2017 OK i think i got it Under Main Memu - Save New Config This works under Retro Arch But how do this on Hypespin or other frontend to load correct setup of controls for right emulator?
thatman84 Posted January 17, 2017 Posted January 17, 2017 What version of retroarch ? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
pofo14 Posted January 26, 2017 Posted January 26, 2017 Are you using rocketlauncher? It handles that for you.
Zeaede Posted January 26, 2017 Author Posted January 26, 2017 3 hours ago, pofo14 said: Are you using rocketlauncher? It handles that for you. Yes im using rocketlauncher, i have followed these guides below. But the controls are my less issue, after following these guides i can ran NES emulator and games through rocketlauncher But when adding nes on hyperhq then run hyperspin it dosen't happend anything The roms are renamed and all green on rocketlauncher Dunno if i missed something in anything in ini files settings
pofo14 Posted January 26, 2017 Posted January 26, 2017 14 hours ago, Zeaede said: Yes im using rocketlauncher, i have followed these guides below. But the controls are my less issue, after following these guides i can ran NES emulator and games through rocketlauncher But when adding nes on hyperhq then run hyperspin it dosen't happend anything The roms are renamed and all green on rocketlauncher Dunno if i missed something in anything in ini files settings If you are using rocket launch, and have config per core enabled, there should be a config file created for each system. It typically is named for each system (i.e. Nintendo Entertainment System.cfg). Within each config you can change the controls. So you need to configure RL to look in the right config directory where your config files are located. Have a config setup for each system, that contains the correct controller mappings (as well as overlays/shaders if you use those). If you check out / post RL log it shows where it is looking, as well as the commend it uses to open RetroArch and it should guide you a bit. I am not in front of my PC so I can't give you the exact settings, but if you look at the RetroArch module settings in RL they are all there.
Zeaede Posted January 27, 2017 Author Posted January 27, 2017 When i have a fresh installation of arch i have 17 sub folders When i have setup core for NES and Nestopia i read a turtorial it is cores folder and there i have nestopia_libretro.dll But go from there im unsure But it is these dll files in the cores folder that seperates all the systems controls with arch?
pofo14 Posted January 27, 2017 Posted January 27, 2017 Yes that is how RA works by itself. The module for RL adds some other features. You probably should search the RL forums they have material there, there is a thread all about RA.
Zeaede Posted January 27, 2017 Author Posted January 27, 2017 2 minutes ago, pofo14 said: Yes that is how RA works by itself. The module for RL adds some other features. You probably should search the RL forums they have material there, there is a thread all about RA. 10 min in this video i understood the dll part but this is for launchbox tho, but the dll are configured with RL?
Zeaede Posted January 27, 2017 Author Posted January 27, 2017 9 hours ago, Zeaede said: 10 min in this video i understood the dll part but this is for launchbox tho, but the dll are configured with RL? i done some search and majority seems to run on joypads i want to run it on keyboard for now arcade later haven't found so much turtorials there btw i got hyperspin to work now, wrote wrong path for launch ini
Zeaede Posted February 13, 2017 Author Posted February 13, 2017 On 2017-01-27 at 2:59 PM, Zeaede said: 10 min in this video i understood the dll part but this is for launchbox tho, but the dll are configured with RL? i done some search and majority seems to run on joypads i want to run it on keyboard for now arcade later haven't found so much turtorials there btw i got hyperspin to work now, wrote wrong path for launch ini could run nes games through hyperspin withouth touching hyperhq all done through rocketlauncher with roms emulators?
Zeaede Posted February 13, 2017 Author Posted February 13, 2017 OK i think i figured out how to do remaps When launched a game, ex NES at first start the windows is small There i see menu with command > Menu toogle When in Menu toogle i more commands > go to controls But there it seems i only can change for joypad not keyboard?
