warpedfenix Posted February 1, 2017 Posted February 1, 2017 hey guys i'm working on a sheild tv and sega cd in hyperspin and i'm having problems with the bios directory. i turn on hyperspin and select a game thats not sega cd and i hit F1 to go to retroarch menu to change the directory of my Bios and i can't change where the bios at located it won't even let me select internal memory just Application Dir. so i decided to move the bio files to the stock location but it seems i can't find the retroarch program file. Both the games and Bios for sega CD work within RA alone. Does everyone have there sheilds rooted?
jcort154 Posted February 7, 2017 Posted February 7, 2017 This helped me when I had trouble with Sega CD launching from Hyperspin. I suspect you are hitting the same RA bug as someone else. It has a different .cfg file if you launch games in RA or when you use a launcher like Hyperspin. SO, you MUST make config changes after launching a game with Hyperspin... Choose a system without a bios, ie. launch an Atari 2600 game, THEN go into settings->directories and change the system folder to your folder holding RA bios files. Then EXIT RA through it's menu to save config.
warpedfenix Posted February 9, 2017 Author Posted February 9, 2017 i tired launching a NES game and i went to the retroarch menu i went to systems->directories to change the folder to where my bois are i can't go to the file where my Bios file is located the only file i can veiw is data\data\com.retroarch which has a bunch of folders in it but if i got on file explorer app or plug it into my pc i don't see where the folder is located. I got it to work but what i had to do was put the bios on a micro SD card and the retroarch within hyperspin was able to find it
thatman84 Posted February 9, 2017 Posted February 9, 2017 Maybe something has changed with android permissions in the latest update. i will have a little go later tonight Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
