GMAXXX Posted February 18, 2017 Posted February 18, 2017 Hi, New to HS, and am having a weird problem. Have been customizing and tweaking my setup (HS > RL > RetroArch), when suddenly HS won't launch games anymore :/ The games work fine when I launch them from RocketLauncherUI.exe (using mame2003_libretro), but when I try from HS, it just doesn't do anything when I select a game! The log suggests that my RocketLauncher integration settings are ok? 07:31:59 PM | HyperSpin Started 07:31:59 PM | Going windowed mode 07:31:59 PM | Checking for updates 07:31:59 PM | Update Check Complete 07:31:59 PM | Startup program unavailable 07:31:59 PM | Error intializing joysticks 07:31:59 PM | Menu Mode is multi 07:31:59 PM | Loading Main Menu.xml 07:31:59 PM | Main Menu.xml successfully loaded 07:32:00 PM | Main Menu wheel loaded successfully 07:32:01 PM | Loading MAME.xml 07:32:02 PM | Main Menu.xml successfully loaded 07:32:02 PM | MAME wheel loaded successfully 07:32:05 PM | Launching Game 07:32:05 PM | Using HyperLaunch 07:32:05 PM | Getting Launcher path 07:32:05 PM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 07:32:05 PM | Running Launcher 07:32:05 PM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "MAME" "1942" 07:32:07 PM | Loading Main Menu.xml 07:32:07 PM | Main Menu.xml successfully loaded 07:32:08 PM | Main Menu wheel loaded successfully 07:32:09 PM | Exit program unavailable 07:32:09 PM | Quiting Hyperspin 07:32:09 PM | Bye!
gigapig Posted February 18, 2017 Posted February 18, 2017 Could it be that Rocketlauncher is still running in the sys tray and you have not rebooted.
jfp Posted February 18, 2017 Posted February 18, 2017 Your rocket launcher path seems fine, have a look and see if your modules are setup correctly in rocketlauncherUI and check your frontends under rockertlauncherUI to see if you have the correct plugin
GMAXXX Posted February 19, 2017 Author Posted February 19, 2017 On 2/18/2017 at 10:01 PM, gigapig said: Could it be that Rocketlauncher is still running in the sys tray and you have not rebooted. Expand Yeah I thought that too, but still no fix after rebooting :/ 07:52:24 AM | HyperSpin Started 07:52:24 AM | Going windowed mode 07:52:24 AM | Checking for updates 07:52:24 AM | Update Check Complete 07:52:24 AM | Startup program unavailable 07:52:24 AM | Error intializing joysticks 07:52:24 AM | Menu Mode is multi 07:52:24 AM | Loading Main Menu.xml 07:52:25 AM | Main Menu.xml successfully loaded 07:52:25 AM | Main Menu wheel loaded successfully 07:53:31 AM | Loading Daphne.xml 07:53:31 AM | Main Menu.xml successfully loaded 07:53:32 AM | Daphne wheel loaded successfully 07:53:33 AM | Loading Main Menu.xml 07:53:33 AM | Main Menu.xml successfully loaded 07:53:33 AM | Main Menu wheel loaded successfully 07:53:35 AM | Loading MAME.xml 07:53:35 AM | Main Menu.xml successfully loaded 07:53:35 AM | MAME wheel loaded successfully 07:53:40 AM | Launching Game 07:53:40 AM | Using HyperLaunch 07:53:40 AM | Getting Launcher path 07:53:40 AM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 07:53:40 AM | Running Launcher 07:53:41 AM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "MAME" "1943kai" 07:53:42 AM | Launching Game 07:53:42 AM | Using HyperLaunch 07:53:42 AM | Getting Launcher path 07:53:42 AM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 07:53:42 AM | Running Launcher 07:53:42 AM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "MAME" "1943kai" 07:53:48 AM | Loading Main Menu.xml 07:53:48 AM | Main Menu.xml successfully loaded 07:53:49 AM | Main Menu wheel loaded successfully 07:53:50 AM | Exit program unavailable 07:53:50 AM | Quiting Hyperspin 07:53:50 AM | Bye!
GMAXXX Posted February 19, 2017 Author Posted February 19, 2017 On 2/18/2017 at 11:34 PM, jfp said: Your rocket launcher path seems fine, have a look and see if your modules are setup correctly in rocketlauncherUI and check your frontends under rockertlauncherUI to see if you have the correct plugin Expand I've included screenshots of the main config windows - any more places to check? Would pasting the RocketLauncherUI log be of any use?
gigapig Posted February 19, 2017 Posted February 19, 2017 Yes post your RL log set to troubleshooting. Also do you have more then one Hyperspin install and you are using the correct one?
gigapig Posted February 19, 2017 Posted February 19, 2017 On 2/19/2017 at 8:01 AM, jfp said: Run hyperspin as admin? Expand I've noticed you make this suggestion on another thread, is it just to rule something out or another reason for doing so? I recently set Hyperspin to run as admin but once you do so you need to set everything else related as admin which just became annoying. Eventually I reset everything back as it did not help in my case.
jfp Posted February 19, 2017 Posted February 19, 2017 If rocket launcher is set to run as admin or user doesn't have privileges to run the emulator... nothing happens
jfp Posted February 19, 2017 Posted February 19, 2017 If hyperspin is set to admin basically everything it runs is run as admin
gigapig Posted February 19, 2017 Posted February 19, 2017 On 2/19/2017 at 8:36 AM, jfp said: If rocket launcher is set to run as admin or user doesn't have privileges to run the emulator... nothing happens Expand Ok cool. He or someone else would have to have set RL to admin though.
jfp Posted February 19, 2017 Posted February 19, 2017 Yeah or he downloaded an emulator that didn't have the permissions set correctly, or put it in a location where admin rights is required. (this happens sometimes)
GMAXXX Posted February 19, 2017 Author Posted February 19, 2017 On 2/19/2017 at 8:37 AM, jfp said: If hyperspin is set to admin basically everything it runs is run as admin Expand o..m..g.. I don't know why I didn't think of this!! Well there's a couple of hours wasted Thanks so much for your help!
