thenoob Posted February 27, 2017 Posted February 27, 2017 Hey hey ia there any way in the CFG for retroarch to setup one shader for default on all the systems retroarch is emulating? say you want to use the lottes crt for all...any way to input that in the CFG? I looked around and couldn't find an exact line dedicated to that. just curious!
thatman84 Posted February 28, 2017 Posted February 28, 2017 Um I don't think it's in the retroarch.cfg because you need a core/content to be loaded. there probably is a way but maybe just load a game and set the shader up. Save core override. Do that for each core. Or or set it on one core then just open the other cores, hit save core override without setting the shader. load all the cfg files in notpad++ then add the shader lines from the core you set it for to all the others you didn't. (If that makes sense) Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 28, 2017 Author Posted February 28, 2017 Kind of does yup im just scared to do anything in retroarch as I just finished setting up my tankstick for all the systems by copy/pasting the default cfg into each system cfg....and made them read only. ive never loaded a core/game in retroarch by itself, only used it through HS, I'm scared I'll fudge everything up. For me, it's a tough propgram to wrap my hear around. A lot of steps, maybe it's just me
thenoob Posted March 3, 2017 Author Posted March 3, 2017 Managed to figure it out, it's kind of a long way but I'm sure everyone on here knows where to edit each systems cfg to activate it
