michelmo Posted March 1, 2017 Posted March 1, 2017 Hi, I try search bur find nothing. For Hyperspin Android I will try explain my request and sorry for my english, I want create a folder name my games. In this folder i want put some games from different system, exemple : one from dream cast, one from PSP, one from PSI and more and more, so in the "my games.ini" i will write can we have more on emulator ? It's for make a new and personal wheel. I write in red under for all understand. [exe info] path=H:\hyperspin\emulators\my games\ rompath=Emulators/my games/roms/ userompath=true exe=com.reicast.emulator/ Here can we more on emulator romextension=CDI,cdi,GDI,gdi,ISO,mdf,mds Thanks for your time.
thatman84 Posted March 1, 2017 Posted March 1, 2017 This feature is not available. Don't think anyone has a way to do it. the exe line will just launch the 1st emulator it finds you have installed Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
michelmo Posted March 1, 2017 Author Posted March 1, 2017 Thanks for reply, I think it was possible something like this : romextension=CDI,cdi,GDI,gdi,ISO,mdf,mds I will try and search search search again, any idea is welcome Thanks.
thatman84 Posted March 1, 2017 Posted March 1, 2017 Sorry to break it to you You can ONLY launch games from 1 emulator per wheel. It's been asked before unless you come up with some programming magic, what you want to do is not going to work. Never say never EDIT: forgot to say you can launch multiple emulators but you can't pass it the rom name so that don't work. Same method you can launch multiple android installed games aswell just not games from multiple emulators Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
michelmo Posted March 1, 2017 Author Posted March 1, 2017 No worry thatman84, perhaps in future, like I say there is alway a way.
reznnate Posted March 1, 2017 Posted March 1, 2017 This isn't possible today. One way this COULD be implemented in the future is to define an emulator needed PER game in the gamesdbase.xml. Again, this feature isn't implemented.
michelmo Posted March 1, 2017 Author Posted March 1, 2017 I my search about my stupid idea I find this, it's a game.ini exemple : # This file is only used for remapping specific games to other Emulators and/or Systems. # If you don't want your game to use the Default_Emulator, you would set the Emulator key here. # This file can also be used when you have Wheels with games from other Systems. # You would then use the System key to tell RocketLauncher what System to find the emulator settings.
thatman84 Posted March 1, 2017 Posted March 1, 2017 2 minutes ago, michelmo said: I my search about my stupid idea I find this, it's a game.ini exemple : # This file is only used for remapping specific games to other Emulators and/or Systems. # If you don't want your game to use the Default_Emulator, you would set the Emulator key here. # This file can also be used when you have Wheels with games from other Systems. # You would then use the System key to tell RocketLauncher what System to find the emulator settings. This is for windows not android got to be a bit careful. Keep your searches to the android forum for things like this. reznate had a sticky post about settings and I have a couple of settings file guides that explain most things Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted March 1, 2017 Posted March 1, 2017 @reznnate did you see the roms in folders work around someone posted months back? Just wondered if there may be a way to add everything needed (rompath, exe & params) into one line of an android games type xml. im not going to try it though Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
michelmo Posted March 1, 2017 Author Posted March 1, 2017 I read android section here, not finish all but I will, I nead read Windows section to because I'm newbie on Hyperspin and I discover How-to. Very thanks you for your help guys.
reicast86 Posted March 30, 2017 Posted March 30, 2017 Hi sorry, and use retroarch with multi roms ita possible?
