onesikcoupe Posted April 11, 2014 Posted April 11, 2014 Just have a quick question regarding best practices when installing Hyperlaunch and HyperlaunchHQ. Should these two be placed in the root of the Hyperspin directory (folder) or in a subdirectory (folder) or are there any advantages or disadvantages of a subdirectory? TIA SIK
gigapig Posted April 11, 2014 Posted April 11, 2014 Best practice is Hyperlaunch in a folder within Hyperspin, and Hyperlaunch HQ in a folder within the Hyperlaunch folder. But you could put them where you like, but I see no reason to. Check out my mame video guide if you need more help.
32assassin Posted April 11, 2014 Posted April 11, 2014 Hyperspin/Hyperlaunch/HyperlaunchHQ the good thing about putting Hyperlaunch in the Hyperspin folder is that you can use a relative path in your Hyperspin settings ini file. Hyperlaunch_Path=HyperLaunch\ This is the same folder structure you will find when you update your files using GIT. It makes it very easy to upgrade when you simply copy and past the Hyperlaunch folder into your Hyperspin folder.
