Tony4Fingerz Posted March 30, 2017 Posted March 30, 2017 Hi guys, im looking to add Aimtrak Light guns to my cabinet but as it's already built I'm looking for a compatible wireless receiver for the guns, does anyone know of one? cheers
KlopjerO Posted March 30, 2017 Posted March 30, 2017 aimtrak has no wireless sollutions.. there are alternative light guns that work wireless or you could use wimmotes as a lightgun.. or you could look for complicated solutions like wireless usb hubs you can plug your aimtracks into.. but doubt if anyone has ever made such a setup.. | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
Tony4Fingerz Posted March 30, 2017 Author Posted March 30, 2017 4 hours ago, klopjero said: aimtrak has no wireless sollutions.. there are alternative light guns that work wireless or you could use wimmotes as a lightgun.. or you could look for complicated solutions like wireless usb hubs you can plug your aimtracks into.. but doubt if anyone has ever made such a setup.. Thanks mate. Ill look into other options. Really like the Aimtraks but not keen on modifying my completed cab to much.
Guest Posted March 30, 2017 Posted March 30, 2017 If you mean wireless for the bar that goes over the monitor, then you could make a wireless solution for that as it's literally only leds that the gun uses to find its position. The led bar doesn't communicate back to the computer.If you want wireless for the guns themselves then that isnt possible as already mentioned. I've used a few different guns before I got the aimtraks and they are no where near as good. I'd seriously consider getting the aimtraks and figuring out how you can make them work with your cab, as they are so much better than anything else. Sent from my iPhone using Tapatalk
Tony4Fingerz Posted March 30, 2017 Author Posted March 30, 2017 2 hours ago, tonesmalone said: If you mean wireless for the bar that goes over the monitor, then you could make a wireless solution for that as it's literally only leds that the gun uses to find its position. The led bar doesn't communicate back to the computer. If you want wireless for the guns themselves then that isnt possible as already mentioned. I've used a few different guns before I got the aimtraks and they are no where near as good. I'd seriously consider getting the aimtraks and figuring out how you can make them work with your cab, as they are so much better than anything else. Sent from my iPhone using Tapatalk Yeah I'm just wanting the bar that sits above the monitor wireless as I don't want to drill through cab and have wires showing its my first cab and just a spur of the moment thing decided I now want light guns..... ill try and find some info, hopefully someone's done it already, I'm sure they would have. thanks
Guest Posted March 30, 2017 Posted March 30, 2017 Yeah I'm just wanting the bar that sits above the monitor wireless as I don't want to drill through cab and have wires showing [emoji4] its my first cab and just a spur of the moment thing decided I now want light guns..... ill try and find some info, hopefully someone's done it already, I'm sure they would have. thanksThe sensor bar is just a set of LEDs that need to be powered. It would be pretty simple to modify the unit to run off batteries. Sent from my iPhone using Tapatalk
KlopjerO Posted March 31, 2017 Posted March 31, 2017 7 hours ago, tonesmalone said: The sensor bar is just a set of LEDs that need to be powered. It would be pretty simple to modify the unit to run off batteries. Sent from my iPhone using Tapatalk here's a list, although it might be dated but hey it's somethinghttp://light-gun.blogspot.nl/p/list-of-light-guns.html | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
bigcam Posted April 26, 2017 Posted April 26, 2017 does anybody know weather you can use an aimtrak with this bar i have a few wii shooters that require more buttons so i was going to use this so i could use both guns
Guest Posted April 26, 2017 Posted April 26, 2017 does anybody know weather you can use an aimtrak with this bar i have a few wii shooters that require more buttons so i was going to use this so i could use both gunsI can confirm that wiimotes work fine with the aimtrak sensors. I can't confirm that it would work the other way around. It likely won't. Sent from my iPhone using Tapatalk Pro
bigcam Posted April 26, 2017 Posted April 26, 2017 Thanks thats good to know even better now all I have to do is get a wiimote thanks alot!!!!!
bigcam Posted June 4, 2017 Posted June 4, 2017 On 4/26/2017 at 5:57 PM, tonesmalone said: can you direct me to a tutorial i cant find one and i cant get my wiimote to sync to the aimtrak bar?
Guest Posted June 4, 2017 Posted June 4, 2017 You don't. The aimtrak is only the led lights the gun and the wiimote use for positioning. You sync/pair the wiimote with a Bluetooth adapter when you're using the aimtrak bar.The dolphin bar has Bluetooth build in, hence why you pair with that when using that. Sent from my iPhone using Tapatalk Pro
