Warfare Posted April 5, 2017 Posted April 5, 2017 Hi, I Opened Virtual Jaguar and its just white, there is no buttons no nothing just a white screen, i didn't launch a game yet. Could it be i am running x32? Thanks
Warfare Posted April 15, 2017 Author Posted April 15, 2017 Anyone have a answer, if not which emulator should I use?
dougan78 Posted April 15, 2017 Posted April 15, 2017 Test a do over? Download again and setup. Not sure if it requires a bios off hand but make sure you have that, and in the right spot. Not all games work so test a known working one or a different game. Good l uckSent from my SM-G920V using Tapatalk
Avar Posted April 15, 2017 Posted April 15, 2017 Is it still the recommended emu? I forget and can't check at work but I know w/e I'm using is working. Have you tried running as administrator?
Aorin Posted April 15, 2017 Posted April 15, 2017 29 minutes ago, Avar said: Is it still the recommended emu? I forget and can't check at work but I know w/e I'm using is working. Have you tried running as administrator? I've been using Retroarch's 4DO core and it's been working like a charm with all those bells and whistles, aka shaders, bezels, etc. BTW Avar, check this site one time per quarter, they always evaluate the best options for each system: http://nonmame.retrogames.com/ Aorin
Avar Posted April 15, 2017 Posted April 15, 2017 Yeah that's what I use I just can't access it at work.
Aorin Posted April 15, 2017 Posted April 15, 2017 I said 4DO core, amazing how I get confused about both systems, OK, since you can't access it I'll put a screen-shot here: 3 minutes ago, agent47 said: Take that list with a grain of salt. Their #1 priority in the ratings is being open source and multi-platform, even if it's not the best. They also seem to choose the RA core over the standalone every time just because. Yeah, these are their priority when evaluating the best, still I myself use Retroarch almost for everything, except PSP, GC, Wii and of course PS2. 3DO and Jaguar are really well emulated, I remember also some time ago some NEC systems needed a paid emulator, I tried NEC under Retroarch and they run perfectly fine. Cores that need more work in my opinion, Reicast, Saturn is amazing but still too demanding. Aorin
Warfare Posted April 24, 2017 Author Posted April 24, 2017 Hello and Thanks for answers, Sorry for not responding, I changed my efault core to use to the 4DO core and I get a error, What am I doing Wrong?
Aorin Posted April 24, 2017 Posted April 24, 2017 2 minutes ago, Warfare said: Hello and Thanks for answers, Sorry for not responding, I changed my efault core to use to the 4DO core and I get a error, What am I doing Wrong? Hey, no problem. Note that 4DO core is for use with 3DO games. virtualjaguar_libretro is the Jaguar core. Aorin
Warfare Posted April 25, 2017 Author Posted April 25, 2017 23 hours ago, Aorin said: Hey, no problem. Note that 4DO core is for use with 3DO games. virtualjaguar_libretro is the Jaguar core. Alright thanks, seems like I read that you said to use the 4DO core and didn't notice you corrected yourself, is that what happened? Anyways, used RetroArch Core (Virtual Jaguar) and games run but sound is terrible and very slow, Could it be my system or that's the way the emulation is?
Aorin Posted April 25, 2017 Posted April 25, 2017 1 hour ago, Warfare said: Alright thanks, seems like I read that you said to use the 4DO core and didn't notice you corrected yourself, is that what happened? Anyways, used RetroArch Core (Virtual Jaguar) and games run but sound is terrible and very slow, Could it be my system or that's the way the emulation is? It could be a lot of factors, actually, but Virtual Jaguar isn't a demanding core, if I compare it to PSX or even worst, Saturn. Are you using some sort of shader or video filter? If so, you could try disabling it and see if solves the slow down. What games are you trying to run? And finally, what are you CPU, GPU and RAM? Aorin
Warfare Posted April 25, 2017 Author Posted April 25, 2017 15 minutes ago, Aorin said: It could be a lot of factors, actually, but Virtual Jaguar isn't a demanding core, if I compare it to PSX or even worst, Saturn. Are you using some sort of shader or video filter? If so, you could try disabling it and see if solves the slow down. What games are you trying to run? And finally, what are you CPU, GPU and RAM? Thanks for quick reply, Im trying to run Alien vs Predator and Doom, tried some other games aswell, no filters or shader unless there enabled by default?, CPU = AMD Athlon 64 processor 3500 2.21 ghz, GPU = Nividia GeForce 7025/ Nividia nforce 630a, RAM = 3.00 GB 2.75GB Usable
Aorin Posted April 25, 2017 Posted April 25, 2017 12 hours ago, Warfare said: Thanks for quick reply, Im trying to run Alien vs Predator and Doom, tried some other games aswell, no filters or shader unless there enabled by default?, CPU = AMD Athlon 64 processor 3500 2.21 ghz, GPU = Nividia GeForce 7025/ Nividia nforce 630a, RAM = 3.00 GB 2.75GB Usable Well, unless it's something else I bet we're just talking about the internal game's poor frame rate, Alien vs Predator is just slow as 20 internal fps if not less, so the only way to achieve a smoother game play would be to have a core over clock like we have for Mednafen PSX, if the CPU can handle it, Driver or Chrono Cross, for instance, which runs variably between 15 and 30 fps in the real hardware, this over clock option locks the FPS to 30, making the game really, really smoother. We don't have such option for other cores, maybe Mupen64 and nothing more. Nothing that they can't add in the future. The above observation works only assuming you really reach the games 60 fps output, while internal fps works differently, so if you don't have sound cracks or something, you're OK, those games were too heavy for the first gen 3D consoles, 32X, Jaguar and 3DO all have bad internal fps rendering 3D games. If this is what you're getting, so you're OK: Aorin
Warfare Posted April 25, 2017 Author Posted April 25, 2017 4 hours ago, Aorin said: Well, unless it's something else I bet we're just talking about the internal game's poor frame rate, Alien vs Predator is just slow as 20 internal fps if not less, so the only way to achieve a smoother game play would be to have a core over clock like we have for Mednafen PSX, if the CPU can handle it, Driver or Chrono Cross, for instance, which runs variably between 15 and 30 fps in the real hardware, this over clock option locks the FPS to 30, making the game really, really smoother. We don't have such option for other cores, maybe Mupen64 and nothing more. Nothing that they can't add in the future. The above observation works only assuming you really reach the games 60 fps output, while internal fps works differently, so if you don't have sound cracks or something, you're OK, those games were too heavy for the first gen 3D consoles, 32X, Jaguar and 3DO all have bad internal fps rendering 3D games. If this is what you're getting, so you're OK: Well I get less FPS for these games, but the problem for me is sound, its a mess! Not sure if its a emulation problem or its just my computer.
dougan78 Posted April 25, 2017 Posted April 25, 2017 I dont think either of those games has been that speed on my setup ever. Mines more of an unplayable slide show, at least in the past. 3.4 ghz 3rd gen i5, 8gb ram too. Sent from my SM-G920V using Tapatalk
Aorin Posted April 26, 2017 Posted April 26, 2017 @Warfare, have you checked in F1 menu, under settings/video, if you have threaded video ON? If it's off, turn it on and see if it makes the games run faster and the sound stops crackling. Aorin
Bungles Posted April 26, 2017 Posted April 26, 2017 I just checked using Retroarch and similar issues, crackling audio. Tried with Threaded Video and the same result. Seems to work fine using Virtual Jaguar however I cannot figure out the controls and cannot find the setup/config.. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Warfare Posted April 26, 2017 Author Posted April 26, 2017 8 minutes ago, Bungles said: I just checked using Retroarch and similar issues, crackling audio. Tried with Threaded Video and the same result. Seems to work fine using Virtual Jaguar however I cannot figure out the controls and cannot find the setup/config.. Are using Virtual Jaguar Emulator or the core for RetroArch?
Warfare Posted April 26, 2017 Author Posted April 26, 2017 29 minutes ago, Aorin said: @Warfare, have you checked in F1 menu, under settings/video, if you have threaded video ON? If it's off, turn it on and see if it makes the games run faster and the sound stops crackling. Well im using the d3d display So, I couldn't find the settings but went in the config files and set it from false to true, did not help with audio "crackling" as @Bungles described it, still has that noise. Also, thanks for helping me, I am probably starting to sound annoying
Bungles Posted April 26, 2017 Posted April 26, 2017 25 minutes ago, Warfare said: Are using Virtual Jaguar Emulator or the core for RetroArch? I was using the Virtual Jaguar Emulator by default, but couldn't locate the controls/config. So I tried using Retroarch and yeah got what you were describing.. Choppy performance and sound bugs. The performance/sound in the Virtual Jaguar Emulator seemed to be fine however once again, couldn't find the start key. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Warfare Posted April 26, 2017 Author Posted April 26, 2017 10 minutes ago, Bungles said: I was using the Virtual Jaguar Emulator by default, but couldn't locate the controls/config. So I tried using Retroarch and yeah got what you were describing.. Choppy performance and sound bugs. The performance/sound in the Virtual Jaguar Emulator seemed to be fine however once again, couldn't find the start key. Could not get Virtual Jaguar to work on my computer, So I thought RetroArch would be better.
Aorin Posted April 26, 2017 Posted April 26, 2017 40 minutes ago, Warfare said: Well im using the d3d display So, I couldn't find the settings but went in the config files and set it from false to true, did not help with audio "crackling" as @Bungles described it, still has that noise. Also, thanks for helping me, I am probably starting to sound annoying Don't feel that way, it's OK to try to figure out a problem. D3D? Is is the only video driver that is working for you? Can you try this, downloading a new nightly Retroarch, rename your current folder to Retroarch1 and try running the game with the new Retroarch with the latest cores without changing any setting to see how it goes? http://buildbot.libretro.com/nightly/windows/x86_64/ Grab the biggest file in the link above. Aorin
