Bobtheaddict Posted April 21, 2017 Posted April 21, 2017 Hello everyone, I am fairly new to utilizing HyperSpin, but I have been around the emulator community for quite some time. In fact, I have built several different cabinets and used a ton of different front ends to manage my collections. Yesterday I picked up a NVidia TV Streaming box "16gig version" and decided to take advantage of HyperSpin's front-end. Here is the guide I have been using "How To Set Up HyperSpin on the NVidia Shield Beginners Guide" from http://www.hyperspin-fe.com/forums/topic/9226-how-to-set-up-hyperspin-on-the-NVidia-shield-beginners-guide/. I am running into an issue with running Don's HyperSpin Tools. I have downloaded his tools and pasted them within a subfolder called Utilities\Tools folder in the HyperSpin folder on my desktop. I have also downloaded the .XML files for the emulators I am going to use to a separate folder called dat. Every time I try to launch Don's HyperSpin List Generator.exe I get the following error message "It is required for Don's HyperSpin tools to be installed in your HyperSpin folder (or a sub folder within your HyperSpin folder). My question to everyone is that am I doing something wrong or using the incorrect file? Thank you for your time and patience. This is what I have done so far in the process: Step 1: In Google Play, search for “RetroArch”. Install the emulator. Step 2: in Google Play, Search for “Hyperspin”. Install Hyperspin. First Steps on Our PC - Download and install HyperSpin to my desktop "I downloaded the most current version HyperSpin 1.3.3 Full Install 1.3.3 (File Size 457mb)" Step 3: Create a folder on your desktop named “Hyperspin” Step 4: Extract contents of your new Hyperspin download into that folder. Step 5: Created all of my Directory Structure within Hyperspin/Emulators/Nintendo Entertainment System Step 6: Inside that folder, create another folder called “roms”. Step 7: Inside the roms folder, place all of your unzipped roms
Kondorito Posted April 21, 2017 Posted April 21, 2017 Hey Bob, welcome! Have you tried placing Don's folder directly in the main HS folder?
thatman84 Posted April 21, 2017 Posted April 21, 2017 Edit- think you need to grab the latest revision which I think is this you have to many folders in your path You have HyperSpin/Utilites/Tools/Checking Tools/Dons Tools/ .exe's You Need HyperSpin/Utilites/ .exe's Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Bobtheaddict Posted April 21, 2017 Author Posted April 21, 2017 Thanks for help everyone! The first thing I tried was copy Don's tools to two different locations: 1. Directly within the HyperSpin folder 2. Shortened the utilities directory to HyperSpin\Utilities, deleted the contents of the folder and unpacked Don's tools. 3. Made sure that I was using the latest version of Don's tools by downloading it again "Dons-HyperSpin-Tools-4.2.6.exe". Unfortunately, I am still receiving the same error message.
thatman84 Posted April 21, 2017 Posted April 21, 2017 @Bobtheaddict just remembered I done an android guide May help you http://www.hyperspin-fe.com/forums/topic/28642-tutorial-hyperspin-android-overview-and-install/#comment-256313 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Bobtheaddict Posted April 21, 2017 Author Posted April 21, 2017 Son of a B@#$%, you are absolutely 100%. I am missing the executable file within HyperSpin. I cannot believe that I missed that. I will see if I can find the 1.4 exe file you mentioned and place in the directory. Thanks again for you help.
