nickleburn Posted May 13, 2017 Posted May 13, 2017 Sorry if I'm posting this in the wrong place or this has been addressed elsewhere (I haven't been able to find it anywhere). In the Platinum benefits explanation this item is listed: "Access to a semi configured 61 system Hyperspin build. No ROMs or bios files are included, you just need to add artwork and paths to your ROMs and 3rd party apps" How configured is this? So assuming someone has all the ROMs for all these systems already renamed properly, and the correct bios files. How much work is needed to finish a basic configuration? Is there any page that has further details about this build (which emulators, of those are they configured for Xbox controllers, any details at all)? I'm looking for an excuse to pickup the Platinum membership but want to ensure that it will truly save me configuration time.
thatman84 Posted May 13, 2017 Posted May 13, 2017 Here is the 1st post. As you not platinum i copy pasted "Following on from the Mame only system set up, here we have a 61 system build which also includes Mame as well. Please be aware that no bios files are included in this build but I will go through each emulator below with what is required This build uses relative paths so can be placed anywhere you like. Thanks Bleasby. All RetroArch systems will have controls set for the Xbox 360 controller the others will need to be set up by the end user, I understand that the Mame controls are already set up for some Ipac controllers so I left them as default. So take a look in the emulators folder at the other emulators, all will need controls setting up but RetroArch already has 360 controls set up as default. Bezels are included only for the handheld systems and fade is on for everything. I have set a "Bezel Change" key to "i" mainly for my testing purposes, you can change it to anything you like, see picture. Also see highlighted "Last Selection", having that enabled will show the last bezels selected every time you start that system." There is plenty more configuration tips for each emulator used in the rest of that 1st post. @gigapig built it and can give your more detail but afaik its a very comprehensive build and will save you time and enable people here to know what setup you have, that makes trouble shooting alot easier Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
joseph2626 Posted May 21, 2017 Posted May 21, 2017 YOU ARRE A PLATINUM MEMBER GO TO DOWNLOAD AND DOWNLOAD THE HYPERSPIN BUILD IT WILL GIVES YOU ACCESS TO MORE THAN 61 SYSTEM THEN WHAT YOU HAVE TO DO IT INSERTING YOUR ROMS AND REMAPPING YOU MIGHT NEED SOM BIOS AS WELL. AND YOU COULD USE MAME AND RETROARCH FOR NEARLY EVERY THING . AND AS MY FRIEND ABOUVE SAID . HOPE THAT HELPED
