"Another instance of RocketLauncherIU is already running!"
Aron313
Hello everyone. I'm new to this but I've been searching all over the web to find a fix to my problem.
I keep getting the error "Another instance of RocketLauncherIU is already running!" and I have tired all the suggestions in other forums but nothing works. I had just downloaded both HS and RL and followed two youtube videos up to this point where i need to open RocketLauncherIU. This is all running on a mac with Parallels running window 7.
Please let me know if you have any suggestions. Thanks
So what happens is i try to open the application RocketLauncherIU and it looks like its starting to load but after the loading box it disappears completely. Sometimes it'll say its running when i pull up task manager and sometimes it won't. If you try to reopen it, that error message will pop up and say that it is already running even though its nowhere to be found.
This may be tricky to solve here but lets have a look at the RLUI log which should be in the same folder as the exe.
Are you talking about the release history?
2016/07/16
 * RocketLauncherUI updated to v1.0.1.7
  - LaunchBox plugin updated to v1.0.2: Changed media types to match current RL plugin
  - Fixed bug causing scrollbar in the frontend artwork form not to work properly
2016/07/05
 * RocketLauncherUI updated to v1.0.1.6
  - LaunchBox plugin updated to v1.0.1: Fixed bug causing game list not updating when switching systems
2016/06/27
 * RocketLauncherUI updated to v1.0.1.5
  - Added plugin for LaunchBox frontend
  - Added new option to add tilde prefix when capturing hotkeys
  - HyperPin plugin updated to v1.0.1: Artwork folder variables moved up to super class
  - Added Use Global checkbox to HotKey form
  - Added checkbox to disable any HotKey to the HotKey form
  - Warning will be displayed when log level is set to DEBUG or lower so the user understands this
    might have impact on RL performance and should only be used when debugging/testing
2016/05/13
 * RocketLauncherUI updated to v1.0.1.4
  - Added support for the new Error_Sounds setting
  - Updated some default values for Fade
  - Updated included Fade Profiles
  - Fixed bug in URL parser on module info form causing URLs with ; character not to work
2016/05/05
 * RocketLauncherUI updated to v1.0.1.3
  - Added support for the new Logging_Include_DLL_Logs setting
  - Fixed bug where use_global was being possible to use together with other hotkeys at system level
  - Added support for the new TRACE_DLL log level
2016/04/21
 * RocketLauncherUI updated to v1.0.1.2
  - Fixed NullPointerException when reading Joystick OEM names from registry
2016/04/17
 * RocketLauncherUI updated to v1.0.1.1
  - Increased ini parser buffer size to fix a bug causing some settings not to be saved on fade profiles
  - PinballX Plugin updated to v1.0.1: Custom systems are added first so that properly named custom systems
    such as Future Pinball, Visual Pinball or Pinball FX2 get added before the standard PinballX names
  - Replaced repeated option appearing in the combo box for the Custom Cursor setting
  - Fixed bug that was causing last update info to be deleted after you reset your ini file settings through
    the UI
  - Added support for the new Shader settings: shaderName, shaderTransparency, shaderColor and shaderChangeKey.
    They can all be set under the Bezel tab
  - Set_Resolution can now be set on a per game basis
  - Fixed bug preventing systems with the ' character on their name to be deleted
  - Replaced DEBUG2 and DEBUG1 log levels with TRACE and DEBUG respectively
  - Load Class Libraries version info into the RLUI panel
  - Added support for the new Suspend_Front_End setting
2016/01/12
 * RocketLauncherUI updated to v1.0.1.0
  - Changed Pause's Force Resolution field validator to use x|y|w|z format instead of integer
  - Added support for the new Restore_Resolution_On_Exit setting
  - Added support for the new Set_Resolution setting which will change your display resolution when
    starting a game
  - Created editor and validator for display settings
  - Moved Virtual_Emulator out of RocketLauncherUI.ini to Emulators.ini. You will need to edit your
    virtual emulators and tick the virtual checkbox for each of them once again
  - Added support for Keyboard Encoder settings Keyboard_Encoder, Keyboard_Encoder_Enabled
  - Added support for WinIPAC and Ultramap settings WinIPAC_Path, UltraMap_Path, UltraMap_Enabled
  - Created new Mappings tab under Settings and moved all keyboard mapping related settings to it (
    Keymapper, Keyencoders, vjoy, etc.)
  - Added support to create/edit Keyboard Encoder profiles under the Keymapper section. WinIPAC supported,
    but also Ultrastik/Ultramap
  - You can now create a default profile under .\Profiles\_Default\%TYPE%\_Default.%ext% and this will be
    used as a base when creating a new keymap profile through RLUI (Required for WinIPAC)
  - Added support for the Base_Rom_Path setting and updated auditing and database generator to make use of it
  - Added do_not_restore option to Hide_Taskbar and do_not_restore, custom_and_do_not_restore to Hide_Cursor
  - Updated RetroFE plugin to ignore comments inside the include.txt file
  - Added ChangeLog form to the Updater, use it to check for all the changes before updating
  - Added new exclude text field to the log viewer filter panel
  - Added new buttons to load the RocketLauncher and RocketLauncher DLL logs directly to the log viewer
  - Added mandatory PluginVersion attribute to all plugins
  - Added support for new Pause setting: Appearance_Duration
  - Added support for new Bezel setting: Game_Monitor
  - Replaced Fade_Rom_Info_Manufacturer setting with Fade_Rom_Info_Publisher and Fade_Rom_Info_Developer
2015/11/08
 * RocketLauncherUI updated to v1.0.0.9
  - Improved modules panel filtering to support non-standard system names. Now any modules referenced
    on the system emulators.ini or games.ini will also show up on the list so you can configure per
    game settings even if you aren't using non-standard system names
  - Fixed bug with alternate game dialog that was causing a NullPointerException when system or emulator
    names weren't being set
  - Added support for new settings: Default_Front_End_Path, Default_Plugin, LEDBlinky_System_Name,
    Fade_Click_Through, DxWnd_Path
2015/10/10
 * RocketLauncherUI updated to v1.0.0.8
  - Added support for the new RomMapping settings: Hide_Parent, Game_Name_Text_Font,
    Game_Name_Text_Options
  - Custom icons are now supported, just name them properly and put them inside .\Media\Custom Icons
2015/09/13
 * RocketLauncherUI updated to v1.0.0.7
  - Added one extra validation for the RocketLauncher.dll unblocking that should avoid errors
    on some particular systems
  - FadeIn and FadeOut can now be enabled/disabled on a per game basis (Games tab)
  - Fixed a bug on auditor when using alternate emulators
2015/08/31
 * RocketLauncherUI updated to v1.0.0.6
  - RocketLauncherUI will now automatically unblock the RocketLauncher.dll file if your Windows
    is blocking it
2015/08/27
 * RocketLauncherUI updated to v1.0.0.5
  - Moved Exit_Emulator_Key and Mode_Rotation_Angle settings to the correct sections
  - Updated RetroFE plugin to work with the newer versions of the frontend
2015/08/16
 * RocketLauncherUI updated to v1.0.0.4
  - Added game name column to the sorting order regardless the column you click
  - RLUI will now check if .NET framework 2.0 is installed and won't let RL start if it isn't
  - Added validation to ExitEmulatorKeyWait setting, 1000ms is now the minimum value accepted
  - Added support for new ServoStik_Exit_Mode ini key, it can also be set on a per game basis
    through the Games tab under specific game options
  - Moved Exit_Emulator_Key from General Settings to the Settings tab (You can now set your exit
    emulator key on a per system basis if you want)
  - Removed support for Exit_Emulator_Key_Wait and Force_Hold_Key since they are no longer needed
    due to the above change
  - Fixed issues with relative paths on ISDs when %RocketLauncherPath% was specified as a BASEPATH
    setting
2015/06/24
 * RocketLauncherUI updated to v1.0.0.3
  - Fixed bug where visibility of some buttons wasn't being updated in context when you
    changed your active Frontend or selected plugin
  - Added support for new settings: JoyIDsPreferredControllersOnExit, Pause_Monitor,
    Pause_Screen_Rotation_Angle,Broadcast_Window_Title
  - Fixed TextReader .NET 4.0 bug, using a workaround so the updater should now run properly
    in all machines
  - Added possibility to setup bezels on a per game basis. You can configure it in the Games tab
  - Added path to the RocketLauncher installation being used to the RLUI tab
  - Added support for new ISD key type FileOrFolderPath
2015/05/28
 * RocketLauncherUI updated to v1.0.0.2
  - License info is now added to newly created JoyToKey profiles if exists. You must enable this
    setting in the RLUI panel
  - Added support for the new Virtual_Drive_Drive_Letter setting
2015/05/04
 * RocketLauncherUI updated to v1.0.0.1
  - Correct number of video labels in the HyperSpin plugin
  - Updater will now notify the user when a file can't be updated due to being read-only. The
    update procedure will go through the end and the user will need to fix the problem afterwards
2015/05/03
 * RocketLauncherUI updated to v1.0.0.0
  - First public release under the RLUI name
Ok I just checked the RocketLauncherUI log and there is nothing in there. I'm guessing there should be something in there?
My RocketLauncherUI doesn't work properly too... It seems like it open but doesn't show anything on screen... (I know that it is running because I can see the process on Task manager just like the case above). I'm running it on a Windows 8.1 machine (.Net framework already installed) and have all the C++ assets needed from 2005 to 2015. Here is the log:
INFO 2017-05-27 02:40:58 [1] RocketLauncher.UI.Util.FileUtils RocketLauncher.UI.Util.FileUtils.findDllFolder (: 0) - 7z.dll found in E: \ RocketLauncher \ RocketLauncherUI \ lib
FATAL 2017-05-27 02:40:58 [1] RocketLauncher.UI.App RocketLauncher.UI.App.OnStartup (: 0) - The type initializer of 'SevenZip.SevenZipLibraryManager' has thrown an exception.
System.TypeInitializationException: The type initializer of 'SevenZip.SevenZipLibraryManager' threw an exception. ---> System.Configuration.ConfigurationErrorsException: The configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Configuration section not recognized startup. (E: \ RocketLauncher \ RocketLauncherUI \ RocketLauncherUI.exe.Config line 3)
At System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors (Boolean ignoreLocal)
At System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors (ConfigurationSchemaErrors schemaErrors)
At System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors ()
In System.Configuration.ClientConfigurationSystem.EnsureInit (String configKey)
--- End of internal exception stack trace ---
At System.Configuration.ConfigurationManager.PrepareConfigSystem ()
At System.Configuration.ConfigurationManager.GetSection (String sectionName)
At System.Configuration.ConfigurationManager.get_AppSettings ()
In SevenZip.SevenZipLibraryManager..cctor ()
In SevenZip.SevenZipLibraryManager.SetLibraryPath (String libraryPath)
In SevenZip.SevenZipBase.SetLibraryPath (String libraryPath)
In RocketLauncher.UI.App.validateApp ()
In RocketLauncher.UI.App.OnStartup (StartupEventArgs and)
Would apreciate if someone found the answer for it  ^^"
