mastermark Posted May 19, 2017 Posted May 19, 2017 Is this anything to do with the creators of Hyperspin ?? The themes look the same the layout looks the same ??
Avar Posted May 20, 2017 Posted May 20, 2017 I'd heard HS works on Raspberry Pi but afaik it was still just called HS. Haven't seen anything called HyperPI though personally.
32assassin Posted May 20, 2017 Posted May 20, 2017 HyperPi is an attract mode theme that uses the cinematic themes created by emumovies. http://forum.attractmode.org/index.php?topic=1663.0 HyperPi has nothing to do with Hyerpsin, Its only doing what every other Front-end out their is doing --> Using Hyperspin artwork. Hyperspin does not work on the Raspberry PI, but you can use an Attract Mode plug-in to use Hyperspin themes, this is what I'm doing.
