Moleburt Posted May 30, 2017 Posted May 30, 2017 I just got hyperspin and I am having a heck of a time getting things working in general. I downloaded the Hyperspin Redesign theme, but I'm not sure how you install new themes. I know that you can have a main menu theme and then every console can have subthemes, but I would like to use this as a Universal theme, I'm just not sure how to do that. Any help would be greatly appreciated. Thanks, Moleburt
thatman84 Posted May 31, 2017 Posted May 31, 2017 I dont have experience with the hyperspin redesign theme set. I expect it will be a collection of Main Menu themes/artwork named afer the relevent systems. And system default themes Basically replace all the media (themes, images) in your media/main menu folder with the redesign ones. Making sure the name of those files matches what you have already created....as the name needs to match throught your install (database, settings files etc) The redesign should have new settings files (.ini files) those will dictate how some of the artwork stuff is placed onscreen, thats not in the themes (pointer, special art) The above goes for you system menus where the games are. Just the naming changes a little once inside the system folder. You will get it soon enough. There should hopefully be some instructions on the page you got it from in the download section Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted May 31, 2017 Posted May 31, 2017 Oh forgot to say if that theme set is missing a theme you would like then you will need to create it or ask someone to. Thats the big problem with unversal looking themes. It only has assets for the stuff that was created at the time. Fine if your cool with a bit of photoshop Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
