violentsingalong Posted August 8, 2017 Posted August 8, 2017 Hello, Everyone. Since they're pretty painful to figure out sometimes, I thought I'd share my PC game control mappings with everyone. Everything I use along with a google spreadsheet with notes is in a link below:https://drive.google.com/open?id=0B6HDK020hAlibGN3WWZzSUdoUmM A few things to consider: I use 95% default MAME controls on an IPAC4. I have remapped the ALT key as it was causing problems on Windows during 4-player button mashing sessions As long as your inputs are keyboard-based, you should be able to change one copy of the the vjoy and x360kb files and replace them for most other games. X360ce is tied to VJoy 100% of the time, so you should only have to change vJoy and everything else should be mapped out. My IPAC4 key mappings are as below:
Metalzoic Posted August 10, 2017 Posted August 10, 2017 I'm not sure what you're showing us here. Instead of just setting up & binding controls on a per-game basis you're using a single VJoy profile... or something? The only PC games I've ever run across that seem to require VJoy to work are MKX and SFV (if you're using a keyboard encoder).
violentsingalong Posted August 10, 2017 Author Posted August 10, 2017 14 hours ago, Metalzoic said: I'm not sure what you're showing us here. Instead of just setting up & binding controls on a per-game basis you're using a single VJoy profile... or something? The only PC games I've ever run across that seem to require VJoy to work are MKX and SFV (if you're using a keyboard encoder). Close! Sorry for not being entirely clear. Some of the games do require vJoy, but not all of them... there's a spreadsheet in the link provided that shows what methodology is needed to remap controls for a keyboard encoder. The folders I provided are the profiles I setup in vJoy, AHK, joy2key, etc. Examples: Angry birds games:AHK used to rebind keys to mouse functions. Profiles based on IPAC4 and could be remapped for any mouse based game (AHK profile provided) The Blue Estate:Used an AimTrak light gun. Buttons are Gamepad Buttons in AimTrak config. Used Joy2Key and AHK to map gamepad buttons to Switch Weapon [Left Button] and Reload/Cover [Right Button] (AHK and Joy2Key profiles provided) Mortal Kombat Komplete (MK9) VJoy/X360CE profiles. Profiles are based on IPAC4. Note: Used this method rather than x360kb because I want X360 icons (x360ce) and blocked keys (VJoy) (vJoy profile and x360ce files provided) I also provided the PCLauncher.ini file which shows where the EXE file is to launch each game, a AppWaitExe where applicable, as well as the Pre/Post launch programs (exe's I built to enable/disable vJoy) that need to be used. Does that make sense? If it isn't helpful, no worries.. It would have just saved me a lot of time when I was first learning how to do all of this stuff.
angryherbalist Posted January 19, 2018 Posted January 19, 2018 this is awesome. is there a definitive vjoy/x360ce guide around here? i've been unable to find it... thanks!
