Sega Naomi
darkskwirl
Hello out there. I was just reaching out to see if anyone had any hints or tips for my Naomi setup. I have it up and running but it seems that if Demul stops working, all configuration files are then corrupted and have to be reset. I can do the whole copy the config file and replace it but that can be a nuisance. I have been trying to get Dynamic Golf running but it fails soon after the initial boot up screen. When I then leave the game and try something new, all settings (controller) have been removed.
Any advice or tips? I have read all the module notes and stuff from djvj but I wasn't sure if someone had their own workaround or tip.
Thanks!
I too would like to know about this system. Is it possible for MAME to play these roms correctly? They "play" but slow as all hell and with weird audio issues. is there a plug in somewhere to correct all that?
Can't you add the controller settings to the Demul 0.58.ini, in the modules folder? Or is that just for Atomiswave? I think it's both.
You would copy from the pad.ini in the Demul folder and paste it into the correct section of the module ini.
Sorry to be vague, I'm afk. :)
I think you may be right Giga... I will have to try that. I am not sure if those would become "corrupted" as well. I will have to try a before and after. I think I saw that but I was more concerned with the config file per the notes from djvj in the module.
I will have to give that a shot.
I'm also a bit disappointed for demul, it seems to play all at some degree, but the emulator itself feels like it has still a way to go.
I haven't experienced crashes, maybe I had one or two but I don't get my configuration files reset.
Post system, graphic card, and the rest of info to help you out.
One option could be to set the important files "read only", or simply copy the files from one place every time you play a game or open the emu. I had these problems but with MAME and that is what I do (the former).
I imagine if you add the settings and controller settings to the Demul.ini in the module folder, they are injected into the Demul Pad ini etc when you start the game; so they should not get corrupted.
