Hypertheme 7za.exe missing
TheoNutz
Hiya, i'm just getting around to learning how to do some custom themes so thought i'd check out Hypertheme, it seems a bit restrictive when you try to change video/image sizes but regardless it's a good tool and i'm sure I can use it to my advantage, but when I try to export something as a theme it says '7za.exe' is missing, now this is definately installed so does it have to be in a certain location for Hypertheme to find it? or can I somewhere tell Hypertheme to find it!
Thanks!
I had an issue with this when I first started and Hypertheme had managed to like clone itself to appdata or documents (cant remember which) I moved these files to my Hyperspin-->Hypertheme directory, ran it and it worked. Sorry I cant give you any more information than that.
There should be a 7za.exe in the hyperptheme directory, it may have been removed due to a false flag.
Not sure if you can just copy 7z.exe from the base directory and rename it.
Thanks, tried moving and renaming the 7z.exe but still says same, is there a specific version of 7za.exe because I can't actually find that specific file, just all different versions I have to rename and that obviously isn't working.
