Joy2Key conflicting with xpadder
Creezz67
I have Joy2Key setup to control my main Hyperspin wheel and everything works perfectly, except when I go into a system that uses
Xpadder and then exit that system back into the main wheel, the controls no longer work.
I have tested in systems that use either emulators own controls or Joy2Key and they are both fine so it must be Xpadder.
Is there something I am missing ?
Thanks in advance
why do you have two programs that do the same thing?
if you think their is a problem with Xpadder; remove it and  configure Joy2Key for the systems that need Xpadder.
witch should be Zero since most emulators have joystick support
