ticmike Posted September 27, 2017 Posted September 27, 2017 I have already got Hyperspin all set up on my pc running into my arcade cab (so got files, artwork, roms etc..) can I easily move this over to my android box (Being Nvidia Shield) or are the systems (windows - Android) totally different set ups?
thatman84 Posted September 27, 2017 Posted September 27, 2017 They are basically the same although compatibility of theme artwork and animation is not perfect. If your shield and cab are on the same network you could try setting up a shared drive and running it on shield to see how mashed things are. So long as the Hyperspin folder is on the root of the drive the android app will pick it up automatically. Ideally you will need a clone of your Hyperspin folder so you can edit things that dont look right without messing with your cab. Then its only a case of changing the rompaths and launch commands in the .ini files Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
