jeffy Posted October 23, 2017 Posted October 23, 2017 I got mame added to rocketlauncher along with the games, and can get it running, but now the problems I'm having are whenever I close Rocketlauncher all of my game disappear and I have to run the audit again to get them back in Rocketlauncher, also if I open Hyperspin and try to open the mame sub wheel from the main wheel it closes hyperspin how do I fix these issues?
Metalzoic Posted October 24, 2017 Posted October 24, 2017 To get your game list to show in RocketLauncher I believe you always have to run audit each time. Totally normal if I remember right. For the Mame wheel problem it sounds like you simply don't have something setup right. Sounds to me like it is going to load your DB info and it crashed because you have it wrong so the first thing I would check would be that your database is actually named and formatted correctly, naming must be 100% exact with punctuation, caps etc... It could also be some of your wheel art or themes named/added wrong or anything else related to the actual loading of the wheel.
jeffy Posted October 24, 2017 Author Posted October 24, 2017 i haven't done anything other than try to add mame, I wounder if maybe what I named mame as vs the name of the exe file might have something to do with it. the exe. file it's self is "mame64" where as when adding it to rocket launcher i just typed in "mame"
adamg Posted October 24, 2017 Posted October 24, 2017 DO you have hyperspin set as default frontend in rocketlauncher it both places?
