hyperspin setup cd?
subzero1970
What would you want to see on the DVD? Could only be the 3 main downloads extracted into the correct folder structure. Everything else is specific to your machine.
Hyperspin has no install files. Any program you need to install will fall under 3rd party software.
nobody is going to distribute any 3rd party software on a CD/DVD and post links on this site.
as far as setting up Hyperspin,
-Download :
HyperSpin Install Files v1.3.2.0
HyperLaunch v3.0.0.9 (Full Install)
HyperLaunchHQ v1.0.13.0
HyperLaunch v3.x (Media Pack) (Optional)
Install instructions:
-Extract Hyperspin 1.3.2.0 and place in --> C:Hyperspin\
-Extract HyperLaunch v3.0.0.9 place in --> C:Hyperspin\Hyperlaunch\
-Extract HyperLaunchHQ v1.0.13.0 place in --> C:Hyperspin\Hyperlaunch\HyperlaunchHQ
-Extract HyperLaunch v3.x (Media Pack) (Optional) place in --> C:Hyperspin\Hyperlaunch\Media
Open Settings.ini
C:Hyperspin\Settings\Settings.ini
copy the path to your Hyperlaunch folder
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Sony PSP
Hyperlaunch_Path=[color="#FF0000"][b]HyperLaunch\[/b][/color]  ( if you place Hyperlaunch in Hypespin you can use a relative path)
finally Update ALL your XMLs here
http://hyperlist.hyperspin-fe.com/
Update Hyperlaunch and HyperlaunchHQ with GIT here
http://www.hyperspin-fe.com/forum/showthread.php?27528-HyperLaunch-GIT
any step after this is determined by your
machine
3rd party software
controller
emulators you have installed
paths to your roms, emulators, 3rd party software.
so u could run the FE from cd/dvd and just have to setup your emulators, i have 32 emulators on my peecee, have fannied about with HS before but got nowhere really, gave up eventually!
Sounds like a nightmare. It would be bloody slow if it even worked, I'd probably end up smashing my PC up if I had to deal with that.
you can run it of a DVD if you want to limit yoruself to bad performance and a 4.7 Gig capacity.
I notice some performance loss when I run my set up from a portable drive.
my roms are in a J drive,
J:System Name\romname.zip
my emulators are in located in
C:Hyperspin\Emulators\Emulator name\version number\emulator.exe
My virtual CD/DVD drive is F:
all this paths are saved in a Hyperlaunch set up file
if I was to save this set up on a DVD, and you tried to run it on your system
Hyperlaunch will try to:
look for your roms in a J: drive
look for the emulators in C:Hyperspin\Emulators\
load an ISO in the F: drive
I'm going to make the assumption that you don't have any of my paths. My set up will not work with your folder structure.
