tonyd6269 Posted December 21, 2017 Posted December 21, 2017 I just picked up a complete arcade upright system that boots directly to Hyperspin... how do I toggle between Hyperspin and back to Windows? I assume its a keyboard command. Sorry but obviously I'm a novice with this stuff. Thanks!
thatman84 Posted December 21, 2017 Posted December 21, 2017 Sorry but generally we cant/dont support products that are paid for. Hyperspin is a free program for the do-it-yourself market. As theres a ton of different ways to configured it it wil be a case of play and see. Or ask the seller for support. Someone may chime in with suggestions but I dont use a pc or cab myself. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tonyd6269 Posted December 21, 2017 Author Posted December 21, 2017 Thanks and understood... wonder if I can just 'tab' and scroll through the control settings to find which key exits out of Hyperspin? I guess I could try that but I really don't know what I'm looking for in all those control options.
Kondorito Posted December 21, 2017 Posted December 21, 2017 Hey tony, welcome to the forums If you press the "Windows" key in your keyboard, you should be able to see the Windows bar and navigate through there wherever you want in the system. If what you want is to configure Hyperspin to not start with Windows, or to not shut down the PC when you exit it, you can do Ctrl+Alt+Delete while being in Hyperspin, and when Windows displays the system options, choose "Start Task Manager". In there you will be able to end HS. Then you can go to the HyperHQ executable in the Hyperspin main folder and configure the Startup and Shutdown. Hope this helps!
tonyd6269 Posted December 21, 2017 Author Posted December 21, 2017 Thanks for the reply and that definitely helps... I want my machine to continue starting up right to Hyperspin but if I wanted to get to Windows to make a change to a setting I was just wondering how to do this. I will try the "Windows" key and see if that gets me to Windows... so when I'm done in Windows how do I get back to Hyperspin?
Kondorito Posted December 21, 2017 Posted December 21, 2017 You will always have HS visible while surfing through folders. In the Windows bar there will be the Hyperspin icon of the open app; just with a click on it and you will focus back on HS.
tonyd6269 Posted December 21, 2017 Author Posted December 21, 2017 Thank you... I will give it a try and experiment a bit. Thanks again!
