Why are videos not working for Atari in hyperspin?
bpjacobsen
I get black display for all atari 2600 games. Mame works fine. I named all flv files the same as the rom names and pointed to the proper video path in hyper HQ for the atari  wheel. Is there something else I"M forgetting?
Hey! Thinking out loud:
- From where you got those vids?
- Have you tried downloading the set in MP4 instead?
- You could try installing the K-Lite Mega Codec Pack, as maybe is a codec problem with that bulk of atari videos you have
- If you play the vids outside of HS with the regular media player (not VLC or any other) do they play ok?
I created these myself using a free video capture download. same as my mame and nes videos which work fine in hyperspin. I can play this videos fine with WMP. Just odd that it's only the atari ones not working.
No problem. I tested it and I am able to display it correctly here.
Try one more thing, grab this video you shared with me, rename it to Atari 2600.flv for example, and place it in the Media/Main Menu/Video/ folder (you can rename the original Atari 2600 video in the mean time you test). Check if you are able to see the video in the main menu as the Atari video. Let me know.
Strange, as your vid worked fine in my set. I think the easiest thing to do at this point, is to get another video pack (preferably in mp4).
but I thought the vids had to be flv? When I first did the mame videos, I did them in mp4 but they did not work. when I switched them to flv, they worked. I can certainly try one to see what happens. thanks for all of your input,
no dice. I tried an mp4 on breakout and same issue. question, I assume the video file name should match exactly to the rom name correct? At least that's what I did for Mame and nes and those work fine. Can  you please provide a check list of what all I need to confirm for setup? Wonder if I missed something stupid?
File format is not the issue, EmuMovies used to be flv... they have since redone most sets in mp4.
There are some other limitations though... I dont know what they are exactly but things like too high bitrate?... reference frames? Number of passes? HS will not like these no matter the format.
Hopefully someone else can chime in with specifics.
Check that the video filenames are exactly (case sensitive) as the database entries in the Atari 2600.xml, and that the videos are in the Media/Atari 2600/Video/ folder (assuming you have set "Atari 2600" as the system name everywhere (case sensitive).
The last thing you can try, is to rename and paste one non working atari video in the place of a working mame/nes one, and see if it displays in that system. If it does, then something sonewhere on the Atari paths configured is not ok. I do not believe the vids are bad, as I tested the one you uploaded in my HS and worked fine.
I copied the breakout atari vid and renamed it Defender in the mame vid folder. it displayed fine under mame. The full name shown in the DB file is Breakout - Breakaway IV (1978) (Atari) [o1] and that is exactly what I named it. that full string is what is between the quotes under gamename. Here is the full entry from the xml:
<game name="Breakout - Breakaway IV (1978) (Atari) [o1]" index="true" image="b">
    <description>Breakout - Breakaway IV (1978) (Atari) [o1]</description>
    <cloneof></cloneof>
    <crc></crc>
    <manufacturer></manufacturer>
    <year></year>
    <genre></genre>
    <rating></rating>
    <enabled>Yes</enabled>
Man oh man, this is just too much! Makes zero sense! So I decided to update the xml DB file and the rom names for the atari 2600 games. and renamed the videos to match the game names. Also went to HQ and re-entered the vid path to be sure. The games still play fine from hyperspin/RL but no videos. This is driving me nuts! The video plays fine in MAME if I rename one of them and place in the mame folder with the name of one of the mame games. Here is an updated sample of my xml:
<game name="Breakout" index="true" image="b">
    <cloneof></cloneof>
    <crc></crc>
    <year></year>
    <genre></genre>
    <rating></rating>
</game>
I"m attaching a screenshot that shows the roms, the hq vid path and the list of videos. Anything else I am missing?
Hmmm... everything sure looks right, maybe its the theme you are using?
Good one @Spawk, it could be the theme. It might not have a video section established even though there is a video frame in it. Try overriding the atari default theme with the mame or nes default themes and test.
Sorry, theme? what theme? Can you expand on this. Still new to this. Please tell me exactly what I need to do and where. thanks
Damn... not the answer i was hoping for, lol. If you are just using the default theme, chances are its ok.
Every system has a main menu theme and a system theme (or individual game themes).
Will try to explain the best I can:
In HS you can have themes/visuals for the main menu, and inside each system for displaying the games.
You can have a default theme for all the system games, or a theme different per game.
Inside the Media/Atari 2600/ folder, you should have a themes folder. Inside you can have a default.zip file and/or zip files named like the games. HS will read that folder and look for game themes and if none, the default theme. The themes are the ones in charge of showing the art, video and position of those.
You can try checking that folder and if there is a default.zip theme, rename it to anything, copy one of the themes from MAME or NES and paste it there as default.zip or nameofthegame.zip.
Oh crap that was it! There was no theme in the atari 2600 folder. I copied the default from mame and now the videos are working! Sheesh! I  knew it was right under my nose the whole time. Just needed someone to point it out. lol. Thanks so much for everyone's help. Now I just need to figure out what I want to add for the atari 2600 menu video.
