Hyperspin Not Working With Retro Arch
smokinrose
You need to go to the log on the root folder of your hyperspin to see what is going on.
But I can guess that pretty much you didn't assign:
-Roms location folder on hyperHQ and/or
-didn't define roms extension file on hyperHQ
I also guess you are able to see the menu with wheels and sub wheels on hyperspin, but it may not be synced  with the roms as I explained above.
Here is what log says,
03:42:50 PM |  HyperSpin Started
03:42:50 PM |  Going FullScreen
03:42:51 PM |  Checking for updates
03:42:51 PM |  Update Check Complete
03:42:51 PM |  Startup program unavailable
03:42:51 PM |  Menu Mode is multi
03:42:51 PM |  Loading Main Menu.xml
03:42:51 PM |  Main Menu.xml successfully loaded
03:42:52 PM |  Main Menu wheel loaded successfully
03:42:58 PM |  Loading Sega 32X.xml
03:42:58 PM |  Main Menu.xml successfully loaded
03:42:58 PM |  Sega 32X wheel loaded successfully
03:43:00 PM |  Launching Game
03:43:00 PM |  Not using HyperLaunch
03:43:00 PM |  Running in normal rom mode
03:43:00 PM |  Excecutable is retroarch.exe
03:43:00 PM |  Command Line is: "..\Games\Retroarch\retroarch.exe" "After Burner (Japan, USA).32x"
03:43:09 PM |  Loading Main Menu.xml
03:43:09 PM |  Main Menu.xml successfully loaded
03:43:10 PM |  Main Menu wheel loaded successfully
03:43:16 PM |  Exit program unavailable
03:43:16 PM |  Quiting Hyperspin
03:43:16 PM |  Bye!
03:43:16 PM |  Bye!
Expand
I have assigned Roms and Emu as well
It looks like you don't have Hyperlaunch switched out for Rocketlauncher.  I'm not entirely sure though, I'm still new to this program.  I have 32x working in Hyperspin and this is a part of my log that I don't see in yours.
02:56:52 PM |  Getting Launcher path
02:56:52 PM |  Launcher located at E:\RocketLauncher\RocketLauncher.exe
02:56:52 PM |  Running Launcher
02:56:52 PM |  Launcher Command Line is: E:\RocketLauncher\RocketLauncher.exe "Sega 32X" "After Burner (Japan, USA)"
Okay, just messing around and I got lucky,  but I think I replicated your problem.  If you go into HyperHQ under the emulator setting for Sega 32x what do you have your execution option set to?  I'm hoping it's Normal.  If it is switch it to HyperLaunch, that should fix your problem I hope.
  On 4/6/2018 at 10:13 PM, smokinrose said:
I am using rocketlauch Sux I have to manually start a game
If a game starts in RL but not HS then you are not connected to RL properly.
Make sure you have "hyperlaunch" selected in HQ and the path to rocketlauncher.exe is correct in your HS setting.ini
  • 4 months later...
Might not be rlauncher UI your using prolly basic rlauncher your frontend settings in rlauncher ui check em also there is notes for each emulator on the modules it's small icon over it global module settings be on right need more details let me know happy spinning
Sent from my H710VL using Tapatalk
