jambo2018 Posted April 9, 2018 Posted April 9, 2018 Is there any way that Hyperspin can scrape/show the usual game info/blurb/synopsis when highlighting each game? It's my favourite feature with Launchbox and was hoping Hyperpin could mirror the same
Bungles Posted April 9, 2018 Posted April 9, 2018 Yes there is... It just needs someone to unlock it and share the method. @dark13 has done it via embedded swf/fla files sourcing from external files, just need to get the method. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Rowr14 Posted April 9, 2018 Posted April 9, 2018 Sorry Hyperspin doesn't do it as far as I understand. The closest most people have gotten has been to save the info as an image and display it as an artwork layer, and even then I don't think I've seen that idea pick up much steam as it would require a lot of effort. edit - Well I guess I'm wrong. I looked around a bunch when I first joined to see if this had been attempted and found absolutely nothing.
Bungles Posted April 9, 2018 Posted April 9, 2018 I just watched his video more closely and it seems you still need to configure a file for each game as its using the file_name as a value and then pulling the data from an xml file. Oh well. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Rowr14 Posted April 9, 2018 Posted April 9, 2018 9 minutes ago, Bungles said: I just watched his video more closely and it seems you still need to configure a file for each game as its using the file_name as a value and then pulling the data from an xml file. Oh well. I think the synopsis stuff is in RocketLauncher files, I figured when I was looking at this stuff a while ago that if you had some method to pull the info out into it's own files or save the scraped info. At the time when I assumed it would need to be then batch made into image files it all seemed possible, but beyond my abilities. I suspect that anyone who want's this stuff badly enough ends up using a different front end, which is why there doesn't seem to be an established project around it here. Hyperspin is great for an arcade cabinet or CRT, all this extra stuff was obviously never intended, though it's impressive to see what people have done with the tools available.
