Kisho Posted May 9, 2018 Posted May 9, 2018 While unzipping the new hyperspin windows defender is warning me there is a Trojan, anyone know what can be causing this?
thatman84 Posted May 9, 2018 Posted May 9, 2018 I'm going to move this topic to the support forum. Its better placed there Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Kisho Posted May 9, 2018 Author Posted May 9, 2018 Just want to clarify that I am using the download link from this site
gre Posted May 13, 2018 Posted May 13, 2018 I see the same warning from Windows Defender. Trojan:Win32/Fuery.A!cl Any ideas?
Spawk Posted May 13, 2018 Posted May 13, 2018 I see the same warning from Windows Defender. Trojan:Win32/Fuery.A!cl Any ideas?The best idea is to have a dedicated HS rig... ie: there is no need for any AV since it will never be downloading anything from untrusted sources.If you simply must use AV, then just add the exe's to the "exclude" or "trusted" list in your AV.Sent from my SM-A520W using Tapatalk
gre Posted May 13, 2018 Posted May 13, 2018 23 minutes ago, Spawk said: The best idea is to have a dedicated HS rig... ie: there is no need for any AV since it will never be downloading anything from untrusted sources. If you simply must use AV, then just add the exe's to the "exclude" or "trusted" list in your AV. Thanks @Spawk - The machine is dedicated but I still run AV just out of an abundance of caution and it's never flagged anything until now. I can add the exception but assuming it's doing its job, I'm more just concerned as to why it's complaining.
Spawk Posted May 13, 2018 Posted May 13, 2018 Thanks [mention=8804]Spawk[/mention] - The machine is dedicated but I still run AV just out of an abundance of caution and it's never flagged anything until now. I can add the exception but assuming it's doing its job, I'm more just concerned as to why it's complaining. It will flag anything that wants access to system files (even changing resolutions and the like). Rest assurred that if it came from here, it is safe though.Sent from my SM-A520W using Tapatalk
