RkH Posted May 31, 2018 Posted May 31, 2018 Hi guys, hi found a bug from don's rom renamer. The fuzzy match detects "disc 1" as "disc 2" in some PSX games. Its really annoying. Is this software gonna be updated some day? Thx!
gigapig Posted May 31, 2018 Posted May 31, 2018 No as it's now abandonware. You could try something else like Tur-matcher. http://hyperspin-fe.com/files/file/5603-tur-matcher/
RkH Posted June 1, 2018 Author Posted June 1, 2018 8 hours ago, gigapig said: No as it's now abandonware. You could try something else like Tur-matcher. http://hyperspin-fe.com/files/file/5603-tur-matcher/ Thank you Gigapig. Do you know if it works with special extensions like cue sheets?
gigapig Posted June 1, 2018 Posted June 1, 2018 5 hours ago, RkH said: Thank you Gigapig. Do you know if it works with special extensions like cue sheets? No sorry. If you rename the cue sheet then you will need to edit the contents of the cue sheet as well so you may need find a tool specifically for that job. What system is that?
RkH Posted June 2, 2018 Author Posted June 2, 2018 On 1/6/2018 at 11:25 AM, gigapig said: No sorry. If you rename the cue sheet then you will need to edit the contents of the cue sheet as well so you may need find a tool specifically for that job. What system is that? I have various systems running on CUE/BIN parcially. For example PSX, i suppose u gonna recommend to move to other extension, isnt it?
gigapig Posted June 2, 2018 Posted June 2, 2018 7 hours ago, RkH said: I have various systems running on CUE/BIN parcially. For example PSX, i suppose u gonna recommend to move to other extension, isnt it? Depends on your situation. I'd recommended getting the Hyperspin ready sets if you have the bandwidth and you can find them. Not sure about PSX as that's a big set.
RkH Posted June 3, 2018 Author Posted June 3, 2018 13 hours ago, gigapig said: Depends on your situation. I'd recommended getting the Hyperspin ready sets if you have the bandwidth and you can find them. Not sure about PSX as that's a big set. Im using PAL sets and, from what i know, hyperspin is ready for USA sets. Also i already have a lot of games and did a lot of work renaming. Romrenamer worked great except from the weird thing that the fuzzy match is not precise.
Brettley Posted July 16, 2018 Posted July 16, 2018 Good to know that this is abandonware. The tutorial videos on YouTube probably won't be updated at all either...
