ajhous44 Posted June 22, 2018 Posted June 22, 2018 Hello. Just finished my third complete reinstall and tutorial follow trying to fix this issue and nothing is fixing it. I can run games through rocket launcher but not through hyperspin. In the hyperspin logs it is stating that it found Rocket launcher and the rom but nothing happens when i hit enter in hyperspin. no error message, nothing... Logs --- Hyperspin: https://pastebin.com/ALBPvVef --- nothing after run RLUI: https://pastebin.com/nveYYY8C -- *** Line 62 it says found rom *** Starting at line 646 it says "Waiting" ? Any help would be greatly appreciated. ***Update: Windows smartscreen asked for permission to run the program the first time launching hyperspin but i have since disabled smartscreen completely.
thatman84 Posted June 22, 2018 Posted June 22, 2018 Try running as administrator and allowing all Hyperspin related .exe files as an exception in your antivirus Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ajhous44 Posted June 22, 2018 Author Posted June 22, 2018 I set my entire Hyperspin+Rocket Launcher drive as an exception. Administrator did not help. I'm close to giving up...
thatman84 Posted June 22, 2018 Posted June 22, 2018 I had a look through but I don’t use RL so hopefully someone else drops by with some more info for you Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted June 23, 2018 Posted June 23, 2018 Also can you set your rocketauncher log to troubleshooting and paste that again after trying again. The normal logs dont really show anything useful. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ninja2bceen Posted June 23, 2018 Posted June 23, 2018 Is there a second instance of RocketLauncher running? If so close it and try againIs it locked on fade in screen or does it not get to that point yet.Yes the error log should help please postSent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ceemobile Posted June 24, 2018 Posted June 24, 2018 I use rocket launcher, a few questions for you.... 1. What emulator are you trying to launch games from? 2. Do the games your trying to play show up all green in RocketLauncherUI? 3. Have you been able to successfully launch from the RocketLauncherUI program directly? If you can your problem may lie in the HyperHQ setup, I had some minor issues launching this way when switching to the new HyperSpin.
