craiganderson Posted May 20, 2014 Posted May 20, 2014 I have hyperlaunch loading xpadder profiles for other systems cant seem to get it to load one for american laser games is it because american laser games doesnt load an emulator through hyperlaunch? thanks craig http://craigandersonthemes.weebly.com/
craiganderson Posted May 20, 2014 Author Posted May 20, 2014 i play with mouse as well\ just testing xbox controller as well thanks http://craigandersonthemes.weebly.com/
craiganderson Posted May 20, 2014 Author Posted May 20, 2014 ok...figured it out i think since i load americal laser games via green hyperHQ not orange HLHQ..i cant have HLHQ load my xpadder profile like other systems so i just set up xpadder to load the profile whenever daphne.exe loaded and then it loads back my hyperspin profile whenever hyperpsin comes back to the forefront problem solved (for now) seems to be working well http://craigandersonthemes.weebly.com/
craiganderson Posted May 20, 2014 Author Posted May 20, 2014 on another note, at least for me daphneloader.exe doesnt actually change the key settings in the .ini file for me have to do it by hand anybody else have this problem? https://www.daphne-emu.com:9443/mediawiki/index.php/Input https://www.daphne-emu.com:9443/mediawiki/index.php/KeyList just fyi http://craigandersonthemes.weebly.com/
urbangangsta101 Posted May 20, 2014 Posted May 20, 2014 craiganderson said: ok...figured it out i thinksince i load americal laser games via green hyperHQ not orange HLHQ..i cant have HLHQ load my xpadder profile like other systems so i just set up xpadder to load the profile whenever daphne.exe loaded and then it loads back my hyperspin profile whenever hyperpsin comes back to the forefront problem solved (for now) seems to be working well Why do you have ALG running through the old (Green) HyperHQ? Just update your system and configure the ALG section on the (Red) HyperLaunch HQ, it's easy. I have all the ALG working on the new Hyperlaunch and they work perfectly. And I have also setup Xpadder profiles for this system to use my Xbox 360 controllers - Although it's not good to play these games with a controller as you need faster reflexes. Aimtrak light guns are the way to go!
rfancella Posted May 20, 2014 Posted May 20, 2014 craiganderson said: I have hyperlaunch loading xpadder profiles for other systemscant seem to get it to load one for american laser games is it because american laser games doesnt load an emulator through hyperlaunch? thanks craig Here is a guide to get ALG and ActionMax setup in HLHQ: http://www.hyperspin-fe.com/forum/showthread.php?29346-Complete-Guide-for-American-Laser-Games-WoW-ActionMax-in-HypeSpin-And-RL craiganderson said: on another note, at least for medaphneloader.exe doesnt actually change the key settings in the .ini file for me have to do it by hand anybody else have this problem? https://www.daphne-emu.com:9443/mediawiki/index.php/Input https://www.daphne-emu.com:9443/mediawiki/index.php/KeyList just fyi That is correct. They are hard coded into the .singe files. You have to use a KeyMapper of some sort. urbangangsta101 said: Why do you have ALG running through the old (Green) HyperHQ? Just update your system and configure the ALG section on the (Red) HyperLaunch HQ, it's easy. I have all the ALG working on the new Hyperlaunch and they work perfectly. And I have also setup Xpadder profiles for this system to use my Xbox 360 controllers - Although it's not good to play these games with a controller as you need faster reflexes. Aimtrak light guns are the way to go! WooT! Correct. You have to be using HyperLaunch to be able to use KeyMapper support built into HyperLaunch. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
craiganderson Posted May 20, 2014 Author Posted May 20, 2014 urbangangsta101 said: Why do you have ALG running through the old (Green) HyperHQ? Just update your system and configure the ALG section on the (Red) HyperLaunch HQ, it's easy. I have all the ALG working on the new Hyperlaunch and they work perfectly. And I have also setup Xpadder profiles for this system to use my Xbox 360 controllers - Although it's not good to play these games with a controller as you need faster reflexes. Aimtrak light guns are the way to go! somebody (a guide or something) showed me how to do it via green hyperHQ works perfectly so not gonna mess with it right now i believe my system is uptodate otherwise did a GIT update last month will do another one soon thanks http://craigandersonthemes.weebly.com/
rfancella Posted May 20, 2014 Posted May 20, 2014 craiganderson said: somebody (a guide or something) showed me how to do it via green hyperHQworks perfectly so not gonna mess with it right now i believe my system is uptodate otherwise did a GIT update last month will do another one soon thanks Really?? If it's running already, go to my guide. Drop all the way to the bottom and look for the line "Now on to RL and ALG!". It's like 3 or 4 steps and it's running. Pretty easy. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
craiganderson Posted May 20, 2014 Author Posted May 20, 2014 yeah it runs perfectly just played several games not gonna mess with it for now thanks http://craigandersonthemes.weebly.com/
