C64 xml
Turranius
I can not quite understand how the Commodore 64 is supposed to be set up with roms. The default XML from HyperList Online seems to be 527 games only, based on TOSEC.
The just finished database is 8076 games: http://www.hyperspin-fe.com/forum/showthread.php?28260-Database-Commodore-64
The tosec package from 2014-02-28 has a lot more then 8076 games, mostly dupes.
Where can I find the xml with 8076 games in it? Once I have that, I can make a script to match the roms from the tosec package and only copy the ones included in the XML to HyperSpin\Roms\Commodore 64.
Thanks!
Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc
http://grandis.nu/software
Tur-Matcher - Match your roms/media/XML files.
Another Idle Volume Adjuster - Automatically control the volume.
How to: Use MAME Extras as material for HyperPause
How to: Use eXoDOS 2.0 as material for HyperPause
Thanks!
When it is released woud you mind sharing that script? Many thanks.
Of course.
Edit: I did a test with the existing xml... hope the new names are more precise, otherwise this will be a pain if you only want the 100% matching roms =) I hate TOSEC
This is just from one game in the xml, trying to find a matching file.
  Quote
# ./xml_match_files.sh
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a2].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a3].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a4].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a5].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a6].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[a].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr ABC].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr L&T][t +4 L&T][a2].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr L&T][t +4 L&T][a3].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr L&T][t +4 L&T][a4].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr L&T][t +4 L&T][a].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr L&T][t +4 L&T].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM+L+T][t +5 REM][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a2][Docs][#074].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a2][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a3][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a4][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a][Docs][#074].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][a][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][Docs][#074].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr REM][t +5 REM][Docs].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr UDI][a].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[cr UDI].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[h Rasta44][a].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic)[h Rasta44].zip
Matching Action Biker (1985)(Mastertronic) with Action Biker (1985)(Mastertronic).zip
Which one to choose. Hmm hmm
I could do an educated guess and just see if we have an exact match with .zip at the end. An exact match starts with an >
  Quote
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a2].zip
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a3].zip
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a4].zip
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a5].zip
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a6].zip
Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC][a].zip
> Matching 10th Frame (1986)(Access Software)[cr TSC] with 10th Frame (1986)(Access Software)[cr TSC].zip
Matching 180 - One Hundred and Eighty (1986)(Mastertronic)[cr WCC] with 180 - One Hundred and Eighty (1986)(Mastertronic)[cr WCC][a].zip
> Matching 180 - One Hundred and Eighty (1986)(Mastertronic)[cr WCC] with 180 - One Hundred and Eighty (1986)(Mastertronic)[cr WCC].zip
Matching 1942 (1986)(Elite)[cr BAM][t BAM] with 1942 (1986)(Elite)[cr BAM][t BAM][a].zip
> Matching 1942 (1986)(Elite)[cr BAM][t BAM] with 1942 (1986)(Elite)[cr BAM][t BAM].zip
Matching 1943 - The Battle of Midway (1988)(Capcom)[cr Ikari][t +2 Ikari] with 1943 - The Battle of Midway (1988)(Capcom)[cr Ikari][t +2 Ikari][a].zip
> Matching 1943 - The Battle of Midway (1988)(Capcom)[cr Ikari][t +2 Ikari] with 1943 - The Battle of Midway (1988)(Capcom)[cr Ikari][t +2 Ikari].zip
Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS][a2].zip
Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS][a3].zip
Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS][a4].zip
Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS][a5].zip
Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS][a].zip
> Matching 1st Division Manager (1993)(Codemasters)[cr SCS] with 1st Division Manager (1993)(Codemasters)[cr SCS].zip
No match for: 3D Pinball (1988)(Mastertronic)[cr PAR]
> Matching 3D Pool (1989)(Firebird Software)[cr REM][Docs][#297] with 3D Pool (1989)(Firebird Software)[cr REM][Docs][#297].zip
That seems better. Putting this on hold until the new XML is out =)
