gigapig Posted August 27, 2018 Posted August 27, 2018 43 minutes ago, lopez888 said: does it look okay ? I can't tell 100% but it might be failing (missing) the USA bios. I usually check from inside Retroarch under Core information. The screen shot shows them missing from my main PC.
lopez888 Posted August 27, 2018 Author Posted August 27, 2018 i just looked inside retroarch like you have done, says missing : sega_101.bin mpr-17933.bin mpr 18811 mx.ic1 mpr 19367 mx.ic1 i have EURO (Euro BIOS) + sega_100 (US BIOS) + SEGA_101 (Jap BIOS) in retroarch>bios (folder) do they need to go in the system folder as well ? what are these mpr ones ?
gigapig Posted August 27, 2018 Posted August 27, 2018 1 minute ago, lopez888 said: i just looked inside retroarch like you have done, says missing : sega_101.bin mpr-17933.bin mpr 18811 mx.ic1 mpr 19367 mx.ic1 i have EURO (Euro BIOS) + sega_100 (US BIOS) + SEGA_101 (Jap BIOS) in retroarch>bios (folder) do they need to go in the system folder as well ? what are these mpr ones ? The top two are the main ones Retroarch is looking for and quite easy to find if you search. They go in the system folder with the rest of your bios files if you have any. If they still don't show then the path to your bios files might be wrong.
lopez888 Posted August 27, 2018 Author Posted August 27, 2018 just put them also in the system folder checked core info got the same message, missing how do edit the path of my bios files , so RetroArch can find them ?
gigapig Posted August 27, 2018 Posted August 27, 2018 1 minute ago, lopez888 said: just put them also in the system folder checked core info got the same message, missing how do edit the path of my bios files , so RetroArch can find them ? In RA menu. move across one to the cogs, scroll down to "Directory" and then it's the first entry.
lopez888 Posted August 27, 2018 Author Posted August 27, 2018 made sure the bios directory path is correct has a (!) next to sega_101.bin + mpr-17933 + mpr-18811-mx.ic1 + mpr-19367-mx.ic1 but think is recognized ? need: (!)Present, Required sega_101.bin (SAturn JP Bios) (!)Present, Required mpr-17933.bi (saturn US/EU Bios) 2 are missing mpr-18811-mx.ic1 mpr-19367-mx.ic1 but i think they are for two specific games (King of fighters 95 + Ultraman)
lopez888 Posted August 29, 2018 Author Posted August 29, 2018 so i managed to get DT Lite 10.4 up and running but still does not mount Saturn CDs automatically in SSF (mounts Sega CD automatically in fusion) ,it is pointed to my SCSI and DT drive (tried both) but does not work, even when i open SSF, mount the disk manually in DTLite and open the disk tray , then close it in SSF, it does not work. In RetroArch, it recognizes the test rom gigapig gave me, Battle Monsters and plays good All my other Saturn Roms do not get recognized when i scan the directory (all are cue/bin and mdf/mds files). Got hold of another Rom set but still they do not get recognized either when i scan the directory please help
gigapig Posted August 29, 2018 Posted August 29, 2018 You could convert your rom set to chd as I think they work OK. How you do that though will require a Google search unless someone knows how. It's been talked about before on these forums.
Aorin Posted August 30, 2018 Posted August 30, 2018 54 minutes ago, lopez888 said: thanks i'll have a look I created this topic last year: http://www.rlauncher.com/forum/showthread.php?5023-New-SSF-Plugin-for-CHD-no-Daemon-tools-needed Aorin
