ShadowFlame Posted October 7, 2018 Posted October 7, 2018 HI! I am wondering how do i add another rom to HyperSpin? Here is the situation, I have the rom for the game "Raiden". When i add that to the MAME rom directory and run it through MAME it works perfectly fine. But, it doesn't show up in the Hyperspin Wheel (I bought the arcade cab with Hyperspin already installed along with mame and roms). Is there an easy way to get the rom/game to show up on Hyperspin? or do i have to go through a lot ot steps? If someone could please walk me through on how to get Hyperspin to see a rom/game that has no issues working if launched through MAME without using the front end... Thank You!
Creezz67 Posted October 7, 2018 Posted October 7, 2018 you just need to go to your databases folder, then MAME and edit the MAME.xml file just add your game at the bottom of the xml to look like all previous games (copy data below to the bottom of your xml) ensure you keep </menu> at the bottom of the xml once done just save and you are done it willl then show up in hyperspin wheel you may have to get wheelart and video for the game but if you have emumovies sync that should be easy enough. <game name="raiden" index="" image=""> <description>Raiden (set 1)</description> <cloneof/> <crc/> <manufacturer>Seibu Kaihatsu</manufacturer> <year>1990</year> <genre>Shoot-'Em-Up</genre> <rating/> <enabled>Yes</enabled> </game> </menu>
ShadowFlame Posted October 7, 2018 Author Posted October 7, 2018 1 hour ago, cataclysm67 said: you just need to go to your databases folder, then MAME and edit the MAME.xml file just add your game at the bottom of the xml to look like all previous games (copy data below to the bottom of your xml) ensure you keep </menu> at the bottom of the xml once done just save and you are done it willl then show up in hyperspin wheel you may have to get wheelart and video for the game but if you have emumovies sync that should be easy enough. <game name="raiden" index="true" image="z"> <description>Raiden</description> <cloneof></cloneof> <crc></crc> <manufacturer></manufacturer> <year></year> <genre></genre> <rating></rating> <enabled>Yes</enabled> </game> </menu> Thank you! it worked! greatly appreciated!
thatman84 Posted October 7, 2018 Posted October 7, 2018 5 hours ago, ShadowFlame said: Thank you! it worked! greatly appreciated! FYi it does not need to go at the bottom. You can slot it into the R section of games for easy letter search later on Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted October 8, 2018 Posted October 8, 2018 i just said put it at the bottom for ease He could have added it in the correct order or use hyperrom2xml, but this seemed the simplest solution
