Jackst333 Posted October 12, 2018 Posted October 12, 2018 First off I just want to say thank you in advance. Taking many months of setting this up, I really like this. With the help from other community folks I was able to troubleshoot and fix most of the errors. Except this nagging one below. It fills up my screen every time a new game is displayed. If this is the Wrong place please let me know I have not ask for help that much in the past 2 years. I believe I setup the Marquee correctly but after letting the system run for over 12 hours I get this Error " Not enough memory Resources are available to process this command. ../Hyper Marquee/Hyper Marquee.exe" There are about 25 error windows all over the back-end of the Hyperspin main window. Once it reaches it max resource I believe it will lock the system up. My setup is Hperspin (FE) HyperMarquee, Hyperspeech and LEDBlinky. Running Hyperspeech and LEDBlinky no issues (Except some LEDBlinky issues that is another topic). Speech works with each game that has a write up on, and LedBlinky Lights. Running HyperMarquee, Hyperspeech and LEDBlinky, Marquee work until errors, but speech will not work with any game. LedBlinky does its own thing (Later Discussion) I am not sure with these combinations is causing to run out of resources or not. Please point me in the right direction. As I have reviewed most of all the video's about this and read all the PDF's. But if only if you know what your are doing you will understand all that. So after two years I am asking for help. I have disable the Microsoft Fetch as this was one of the items I read up on as well. I followed all the basic steps of letting the windows 10 system do its thing to run smoothly. Now I am out of Ideas. Is there any .ini files I need to tweak? So once again sorry if I posted it in the wrong place. Thank You Jack Jack Stephens
Spawk Posted October 13, 2018 Posted October 13, 2018 Wish I could help more but I have yet to tackle this kinda stuff. I notice you don't make any mention of EDS (Event Dispatch System). Have a look at Ninja's video and see if there is anything in there that helps:
Jackst333 Posted October 13, 2018 Author Posted October 13, 2018 Sorry I did not mention this, but yes I followed all the steps. It seems to be I just need to find out why the memory issues. Then I remember that Microsoft uses super fetch and this causes issues with the cache on the memory. So I disable it as I have plenty of Ram but the cache is low. This is causing the lock up I feel. It has been over 18 hours an no failures. So by testing so many things and spending many hours on this I feel that I got this in a working state. Now the only thing is to get Hyperspeech to work along with this. If You remember If you run Hyperspeech and go to mame it reads everything back to you. But once you add this to the Marquee it will not work. So I feel it has to do with a sharing of resources and how you call them. I remember reading some place that you have to call LEDBlinky first with EDS, then assign HQ with EDS and then have the Hyperspech called ledblinky from HyperMarquee. Something like this. I have to do more research, but at least I am getting there. The only thing about taking years to getting a project going is everything needs to be updated or expired and nobody supports it anymore. Therefore I am glas that there is a group that I can ask stupid questions to. Thank you all Plus Ninja's video is spot on. I wish I had this several years ago. Hyperspin has changed alot and Simply Austin was great in talking about how to add stuff. That is why I am back to get as much knowledge as I can. Building out takes time and when it drags on, it seems like you are a failure. Once Thank You all for your kind help so far. Jack Stephens
