matateu Posted October 29, 2018 Posted October 29, 2018 Hi Gamers, can anyone explain how this Hyperspin media folders actually works? I've download all files/folders from Emumovies and I don't understand where to move them. I'm using windows 7 thx Nuno
Bungles Posted October 29, 2018 Posted October 29, 2018 In the Media folder there will be sub folders for each Menu/System plus one for the Front End itself. Within each of those folders is a section for your Images, Video, Sounds and Themes. Images is broken down into parts. Artwork 1-4 are used when a Theme calls for an artwork file that's not present in a them. (Used for default themes) Backgrounds I think is similar and used for default themes. Genre is used for Genre media for that system Letters is used for the lettering system when you hold skip back for forwards. Other is used for pointers. Particle is for effects/transitions I think for when you switch between items. Wheel is where the labels go for each item/game etc. Sound is also broken down into parts. Background Music is used for backing tracks which can play when the item/game with the same name is displaying. System Exit is used for when you exit that system back into main menu. System Start same as the above but for when you enter that system from the main menu. Wheel Sounds are used for each time you move between items in the menu. Themes is a bit simpler. Themes will contain a Default theme which can use artwork items from the Images folder above and/or individual theme items for each game. Video is the simplest. You just need to add video files with the same name as your item. Each theme or a default theme looks in this folder for its partnering video preview. I hope this was helpful. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
benwisecup Posted January 24, 2019 Posted January 24, 2019 This might be a dumb question but I can't find an answer. Is it possible to use a different drive for the artwork folders? I would like to use a second hard drive to house my media/artwork but can't see any way to point to the different locations. Is this possible? Thanks
DomusdelCapo Posted January 24, 2019 Posted January 24, 2019 8 minutes ago, benwisecup said: Esta podría ser una pregunta tonta pero no puedo encontrar una respuesta. ¿Es posible utilizar un disco diferente para las carpetas de ilustraciones? Me gustaría usar un segundo disco duro para alojar mis medios / ilustraciones, pero no puedo ver ninguna forma de señalar las diferentes ubicaciones. es posible? Gracias No es una pregunta tonta amigo es muy usado por varios usuarios Soy DOMUS DEL CAPO tengo mas 18,000 horas en HS, Tienes que usar "mklink" , crea enlaces simbólicos en el caso de MAME y sus manufacturer y placas solo usa la imaginación. https://drive.google.com/open?id=1NvPxKxkzuJAF3p4a1GKs5A_Rv47rLtu5
32assassin Posted January 24, 2019 Posted January 24, 2019 28 minutes ago, benwisecup said: This might be a dumb question but I can't find an answer. Is it possible to use a different drive for the artwork folders? I would like to use a second hard drive to house my media/artwork but can't see any way to point to the different locations. Is this possible? Thanks you can only move videos out of the media folder, wheel, Artowrk1-4 and themes need to stay in your media folder
DomusdelCapo Posted January 24, 2019 Posted January 24, 2019 30 minutes ago, 32assassin said: solo puede mover videos fuera de la carpeta de medios, rueda, Artowrk1-4 y los temas deben permanecer en su carpeta de medios No necesariamente me entiendes o te lo explico. tengo varios sistemas en otras unidades creando enlaces en la carpeta media y no hay problemas así lo uso por mas de 3 años.
DomusdelCapo Posted January 24, 2019 Posted January 24, 2019 HS reconoce los enlaces simbólicos perfectamente un ejemplo de Mame y quiero "Afega" solo creo un enlace simbólico en la carpeta media y coloco un setting y un xml y tengo un sistema con los medios de mame que es un desarrollador así con otras unidades recontra comprobado al 110%.
32assassin Posted January 25, 2019 Posted January 25, 2019 you can move videos out of Hyprspin and change the video folder location in HyperHQ you cannot do the same for media folders creating symbolic links solves this problem, this does not mean that Hyperspin has support to move artwork out of the media folder.
DomusdelCapo Posted January 25, 2019 Posted January 25, 2019 Pregunta: ¿Es posible utilizar un disco diferente para las carpetas de ilustraciones? Respuesta: Si es posible. Nota: No importa si tiene soporte o no para mover a otro disco los medios de comunicación la realidad es que se usa de esta manera por varios años. Si es posible claro que si.
