Getting rid of files without matching roms
Hello, all.  It's been a long time since I've been here but the bug bit me again.
Is there a tool here or elsewhere that will look at my roms folder and say, my artwork folder and move all the artwork files for which I don't have roms to a separate folder?
Thanks in advance.
Welcome back :)
Here you go:
There is a button on the right side that says "Move unneeded roms or media to subfolder". Pressing that button and selecting what you want to clean, it will create a new folder inside the folder it audited called "Unneeded" with all the stuff not being in use.
I can't get the tool to do this for me.  I throws out the error below.  My artwork path is D:\MAME\artwork and the file I'm feeding it is just a list of names with .zip extension in a text file.  I tried to install the latest .net framework files but the installer told me I had the latest already.
Does the stuff below look familiar?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Illegal characters in path.
   at System.IO.Path.CheckInvalidPathChars(String path, Boolean checkAdditional)
   at System.IO.Path.InternalCombine(String path1, String path2)
   at System.IO.FileSystemEnumerableIterator`1.GetFullSearchString(String fullPath, String searchPattern)
   at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
   at System.IO.Directory.GetFiles(String path, String searchPattern)
   at Microsoft.VisualBasic.FileIO.FileSystem.FindPaths(FileOrDirectory FileOrDirectory, String directory, String wildCard)
   at Microsoft.VisualBasic.FileIO.FileSystem.FindFilesOrDirectories(FileOrDirectory FileOrDirectory, String directory, SearchOption searchType, String[] wildcards, Collection`1 Results)
   at Microsoft.VisualBasic.FileIO.FileSystem.FindFilesOrDirectories(FileOrDirectory FileOrDirectory, String directory, SearchOption searchType, String[] wildcards)
   at Microsoft.VisualBasic.FileIO.FileSystem.GetFiles(String directory, SearchOption searchType, String[] wildcards)
   at WindowsApplication1.Class2_xml.move_roms_from_txt_to_subfolder_Click() in F:\Documents\My_Progs\HyperspinChecker\Class2_xml.vb:line 152
   at WindowsApplication1.Class2_xml._Lambda$__3(Object a0, EventArgs a1) in F:\Documents\My_Progs\HyperspinChecker\Class2_xml.vb:line 0
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
HyperspinChecker
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/FrontEnd/Tools/Hyperspin%20Checker/best%20hyperspin%20checker%20media/HyperspinChecker.exe
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
No worries, my friend.  I thought of a clever and easy way to do this:
1. copy all the artwork files from the artwork folder
2. paste them into the rom folder but when asked what to do about duplicates, skip those files (this leaves the ones I want in the artwork folder)
3. once the unwanted files are pasted, they will still be highlighted so cut them from there and paste them somewhere else
Bingo!
Before pressing the button, you need to select the system and press the Check button, after everything shows up listed, then you can press the move button.
