bigdic Posted November 16, 2018 Posted November 16, 2018 I have been using retroarch for a while for emulation but decided to ditch it as much as possible for stand alone emulators where I can. Since doing this the exit on my arcade has ceased to work on everything apart from mame. Rocket launcher has its exit hotkey set but still makes no difference. Pcsx2 used to exit but no longer does Retroarch used to exit but no longer does Demul doesn't exit but never has. All exit fine using ESC on keyboard. I have made a bunch of changes Inc bevels, fades etc but cannot workout what has altered to stop the exit function. Any ideas are welcome.....
dark13 Posted November 16, 2018 Posted November 16, 2018 Check if it works outside HyperSpin, use directly RLauncherUI to launch and check that the exit button in RL is correct (you can set different button for different systems). Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
bigdic Posted November 16, 2018 Author Posted November 16, 2018 Doesn't work in rl either, I have restore frontend on exit and restore resolution on exit set to false?
dark13 Posted November 16, 2018 Posted November 16, 2018 Uhm... I guess the best thing would be posting the problem on RocketLauncher forum including RL's log, something is not working as it should. Those options are usually used to resolve problems with the frontend not keeping focus or when it still runs in the background while playing. Ah, some dektop modding softwares like samurize, xwidget, rocketdock, etc, can cause issues with RL scripts. If you run Windows10 in most cases HS and RL should also have admin rights, so if it is a cab or an HTPC just turn off UAC Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
bigdic Posted November 16, 2018 Author Posted November 16, 2018 Okay, I figured it. It was me being stupid was using joy2keys hotkey for exit. I thought that has been what it was always set at.... When I made a new exit key and simply pressed the arcade exit button instead of using the hotkey assigned in joytokey it worked. doh!
Creezz67 Posted November 17, 2018 Posted November 17, 2018 How many people on this forum post a question only to answer it themselves ??? it must be literally 40-50% !!! Maybe we should be able to like our own posts when we answer them ourselves ?
