Pc Launcher / Steam Help
bigdic
Hey Guys
I have been trying to set up Pc Launcher unsuccessfully for 3 days now with no joy. I have narrowed the problem down to steam and how it is launched. If I set pc launcher to pre launch steam.exe, it launches my steam library and not the game and causes a black screen stall through hyperspin, However if I already have steam launched and open in the background and leave the prelaunch box in the pc launcher empty everything works perfect. So I have attempted to set steam to launch through the start up script app (screenshot below) but it just won't??? any ideas guys this is driving me nuts, I have to missing something obvious, what am I doing wrong here!!!
I have two workaround I can think of. (Not solutions sorry)
Manually set steam to launch on startup through windows itself.
Or add Steam as it's own entry in your HyperSpin wheel and launch it before anything else.
There are instructions in the module notes on how to get Steam to log in on launch. Personally my Steam logs in on Windows startup.
Hey guys I boot straight to hyperspin so no good launching steam on startup through windows/explorer. @gigapig if you mean pc launcher module, I have tried this as said above with poor results. @Rowr14 thanks for the workaround but it's to messy for me. I was hoping there was something I had missed on my startup script..
I also boot straight to Hyperspin with Steam loading at startup. To do this I use Tur-volume adjuster where you can set a wait time so Hyperspin launches after all background apps are loaded.
https://hyperspin-fe.com/files/file/744tur-another6--idle-volume-adjuster/
@gigapig tell me more :) where do you put steam to autostart? shell:startup? I thought this only worked with explorer launched? PS the link you posted has moved but I should able to find it once I get home
