Adding something besides mame, such as dolphin
Tommatt
I did not do a extensive look up over your errors because you have an outdated RL and module,  this might be the problem
it looks like module 2.1.9 is for emulator version 4.0 r6928
you are running emulator version dolphin-master-5.0-9140-x64
update your modules and RL,  try again.
it should take you a full 30 seconds to accomplish this
http://www.rlauncher.com/wiki/index.php?title=RLUI_Updating
you have RL version 1.2.0
00:46:04:502 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.0 (www.rlauncher.com)
you should have 1.2.0,1
http://www.rlauncher.com/forum/showthread.php?4301-RocketLauncher-v1-2-0-1
you have an outdated module
					MEmu := "Dolphin"
					MEmuV := "v4.0 r6928"
					MURL := ["https://dolphin-emu.org/"]
					MAuthor := ["djvj","bleasby"]
					MVersion := "2.1.9"
					MCRC := "2B832CB2"
					iCRC := "F063B9AF"
					MID := "635038268884477733"
					MSystem := ["Nintendo Gamecube","Nintendo Wii","Nintendo WiiWare"]
you should have version 2.2.0
MEmu := "Dolphin"
MEmuV := "v5.0"
MVersion := "2.2.0"
MCRC := "C7DEEF2C"
iCRC := "9DF8C36F"
					MEmu := "Dolphin"
					MVersion := "2.1.9"
					MCRC := "2B832CB2"
					iCRC := "F063B9AF"
MEmu := "Dolphin"
MEmuV := "v5.0"
MVersion := "2.2.0"
MCRC := "C7DEEF2C"
iCRC := "9DF8C36F"
Just did this and got the same error/just the dolphin screen no game.  Did I not do it correctly?
RocketLauncher.log
can you download a stable version of dolphin
such as 5.0 or 4.0.2  or 4.0
and try to use them instead of your current version
the only thing I can find is
00:44:53:922 | MD |     ERROR  | +31    | ScriptError - There was an error waiting for the window "FPS ahk_class wxWindowNR". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
00:44:53:927 | MD |      INFO  | +0     | ExitModule - Started
I don't know what version I have given that I haven't updated an emulator in years, I probably still have version 4.0
you might need to go to the Rocketlauncher forums for assistance if you like to run the latest builds of emulators when they are not supported by the current module
http://www.rlauncher.com/forum/forum.php
Switching to 4.0 seems to have fixed the problem.  I had tried a couple other versions, but saw you mentioned 4.0 so I went with that.
Thank you.  The way it was working I figured it was something I had done wrong somewhere with the coding.
Thank you again everyone.
Now to go back through this thread and read a few replies.  I'm getting cannot find gamecube.ini but I think I've read what to do for this.
Maybe not.   Looking through google and the original hyperspin guide now to see how I create this ini file.
I have ini files for other systems I haven't installed but don't have one for gamecube in there.  Pretty sure I didn't do anything for Mame when I did this.
*EDIT* Figured out what I had wrong.
Ok, I realized my PC deleted hyperhq somehow so I regot that file.  I'm able to get into gamecube, see the list of every game, not just what i own, but when I select one I"m getting this
I think I've solved all there is to solve with Dolphin.  Have it in Hyperspin, have it showing only roms I have, and everything seems to be loading fine.
Thank you again all for your help.  I'd be banging my head against a wall still without all of you.
