craiganderson Posted June 2, 2014 Posted June 2, 2014 Hello, Whenever I do not have fullscreen selected in HyperHQ, hyperspin is windowed while I am on the main wheel themes and system themes, but whenever I select a game, everything goes FullScreen. Is there any way to have "fullscreen" be within a window? Does that make sense? thanks http://craigandersonthemes.weebly.com/
Cryofax Posted June 2, 2014 Posted June 2, 2014 When you select a game the screen is subject to the emulator's settings, not Hyperspin. About the only thing I can imagine getting it to do what you want is run the whole thing within a virtual OS install (like Oracle VM Virtualbox). That then can be run in windowed mode, and everything within that runs fullscreen (including hyperspin), but would only fill the virtualbox window.
Fromlostdays Posted June 2, 2014 Posted June 2, 2014 If I'm understanding you right, you could try setting up the emulators to launch in windowed mode through HLHQ/Emulator settings, and then add WinMaximize into the module. That will launch you into a maximized window, but not fullscreen. Walter:beerglass:
bleasby Posted June 2, 2014 Posted June 2, 2014 On most emulators you just need to choose it to run on windowed mode on HL and set your resolution on the emulator to match your screen resolution. On others you could also set the Windowed mode, enable bezels and use a transparent bezel image with the resolution of your screen. This would avoid the module edition and also the bezel code would hide any window components. Edit: also check if the module does not have the windowed fullscreen or fake fullscreen option under the module fullscreen options. In some of them we already implemented that for you. When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
