johnowhetton Posted June 2, 2014 Posted June 2, 2014 Hi guys, Ive downloaded tons of ROMs for the commodore 64, I've setup the winvice emulator. My problem is with the XML file. I downloaded the one from hyperlist but it doesn't contain any CRC info so when I try to use dons ROM renamer it can't match any of my ROMs with those contained in the XML. Does anyone know where I can get an XML file for The commodore 64 that has the CRC info or can anyone suggest a way around my issue Sent from my Nexus 5 using Tapatalk
gigapig Posted June 2, 2014 Posted June 2, 2014 Personally, I hand picked the games I loved, renamed them and used Hypertools to create a simple xml. There's just so many I can't see my self ever playing them all.
johnowhetton Posted June 2, 2014 Author Posted June 2, 2014 Hmmm yeah I'm thinking maybe I may have to do the same Sent from my Nexus 5 using Tapatalk
rfancella Posted June 2, 2014 Posted June 2, 2014 johnowhetton said: Hi guys, Ive downloaded tons of ROMs for the commodore 64, I've setup the winvice emulator. My problem is with the XML file. I downloaded the one from hyperlist but it doesn't contain any CRC info so when I try to use dons ROM renamer it can't match any of my ROMs with those contained in the XML. Does anyone know where I can get an XML file for The commodore 64 that has the CRC info or can anyone suggest a way around my issueSent from my Nexus 5 using Tapatalk You can use the official xml and rename the roms. If you use the newest HyperTools (Rom Renamer), it can use fuzzy match logic and doesn't need the CRC. It's worth a try anyway. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
johnowhetton Posted June 2, 2014 Author Posted June 2, 2014 Ok Ron I'll try that thanks Sent from my Nexus 5 using Tapatalk
rfancella Posted June 2, 2014 Posted June 2, 2014 johnowhetton said: Ok Ron I'll try that thanksSent from my Nexus 5 using Tapatalk There are a folder on the FTP that has the newest version: /Upload Here/HyperTools Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
johnowhetton Posted June 2, 2014 Author Posted June 2, 2014 Magic thanks Sent from my Nexus 5 using Tapatalk
