sega model2 working 100% in rocketlauncher, but opens at small black audible window in hyperspin.
hollywood6964
So the title says it. Model2 in rocketlauncher works perfectly fine, newest 1.1 version in latest rocketlauncher. 1.2.0.1. Also the latest hyperspin and, it doesn't load near every time. Just a small black window in the upper left corner, in which I can hear the game sound, and it goes back to the hyperspin menu.
I've tried many different versions and reinstallations of model2, going back to .9. I have also tried the regular emulator, and the multi-cpu emulator, and they both work in rocketlauncher, and both do not work properly in hyperspin- same results. Here and there it will open correctly, but most times it won't. Doesn't matter the game.
Also every other emulator I normally use (genesis, snes, nes, mame, etc) work fine. Just not this one.
Anybody had this problem? I'm sure there's a work around, any solution would be greatly appreciated, thanks.
On 2/8/2019 at 5:16 PM, gigapig said:
Have you tried hitting alt-enter to set full screen?
Yeah, been through the normal stuff. There has to be something that could be adjusted to fix the problem.
I found that I couldn't get it to load past the fade screen, ultimately the solution I found was to disable the fade in. Not sure probably unrelated/different issue but thought I'd mention it anyway. Seems like there is something about focus for this emulator.
Not sure if your saying it's just sometimes it loads? Maybe see if theres something to do with if your running Hyperspin windowed or any other applications open that could take focus away.
I don't use fades, but there probably is something related to even using stock settings. Anything suggested?
Also sometimes it loads the first time I open it, or at times certain games seem to load more often than others, although I most don't at all once it small black windows. IDK, something inherently wrong with working with hyperspin, as it's fine with just rocketlauncher.
